Replaced Distributor, cant get timing right!
Old Jul 1, 2006 | 05:36 PM
JBirch_97Prelude's Avatar
Default Replaced Distributor, cant get timing right!
I replaced my Distributor, cap, coil, and rotor, but now I cant get the timing right. Just when I think I got it the Car backfires when I put it in Gear. How do you TDC if the marks are no longer visible also?
Old Jul 1, 2006 | 07:23 PM
ekb16's Avatar
did u jump the service connector b4 trying to set the timing?
Old Jul 1, 2006 | 07:29 PM
Default Re: (ekb16)
I tried it? What exactly does that do?
Old Jul 1, 2006 | 07:57 PM
Chiovnidca's Avatar
Default Re: (RippleSound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RippleSound &raquo;</TD></TR><TR><TD CLASS="quote">I tried it? What exactly does that do?</TD></TR></TABLE>
It keeps the ecu from changing it while you set base timing. You're setting it to the red mark right?
Old Jul 1, 2006 | 11:00 PM
Default Re: (Chiovnidca)
I have been setting it to the white mard
k, ****
Old Jul 2, 2006 | 10:46 AM
Timing marks off by a 1/4 inch. TDC is Correct and the Distributor is all the way right
Old Jul 2, 2006 | 11:45 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RippleSound &raquo;</TD></TR><TR><TD CLASS="quote">I have been setting it to the white mard
k, ****</TD></TR></TABLE>
The white mark is tdc. The red marks are for setting igniton timing.
Old Jul 2, 2006 | 12:31 PM
My pointer is broken off. I got it close to where it should be, but the car continues to back fire.
Old Jul 2, 2006 | 02:37 PM
Car Idles and rev's fine unitl I put it n gear. Then it back fires
type-GGSR
Dec 26, 2007 09:52 AM
okbubbac
May 28, 2007 05:29 AM
DougNuts
Sep 21, 2005 04:38 AM
tianporn
Aug 1, 2004 12:20 AM
