Replaced Cat
Old Jul 5, 2016 | 04:41 PM
Uljima's Avatar
Default Replaced Cat
00 civic with gsr swap+ magnaflow cat
Hello, just installed my new cat, and now I am throwing P0141 code for the secondary o2 sensor. In return I went out and bought a new o2 sensor, and it is still throwing the same code. (Thought it was a faulty o2 sensor, so went in to get another exchange still throwing same code- used Bosch)
My question is what can I check for now, after replace the o2 sensor twice.
I have also checked fuse 15 btw.
Old Jul 6, 2016 | 10:22 AM
tony_2018's Avatar
Fish Twig
Default Re: Replaced Cat
Don't use bosch...either buy a denso or ntk/ngk. I prefer denso.
Old Jul 6, 2016 | 01:25 PM
fcm's Avatar
fcm
Old Fart
Are they heated 02 sensors?
If so check for power, [12V+] to the sensor, should be a yellow/black, supplied by the fuel injector relay in the PGM-FI Main Relay, ground, [should be orange/black] is supplied by the ECU.
What year is the GS-R engine from and what harness are you using?
Old Jul 7, 2016 | 08:00 AM
SpeedRacerEX-R's Avatar
Why no bosch o2?
Old Jul 7, 2016 | 08:38 AM
holmesnmanny's Avatar
Are you actually replacing the rear oxygen sensor that is located behind the cat ?
Old Jul 7, 2016 | 10:02 AM
Uljima's Avatar
I have checked for power coming from the plug and it is good. Gsr is a 99 using obd2b harness from the civic.
I have been doing research for the past hour and people have been saying that the Bosch o2 sensors create many problems on Japanese cars. I have also talked to a shop about this, and they said to just switch it out for a Denso. Than again I can't return the bosch o2 sensor as I already used it(spent 140 on it)
Old Jul 7, 2016 | 10:03 AM
Uljima's Avatar
it's the downstream one
Old Jul 7, 2016 | 09:40 PM
The only job of the rear oxygen sensor is to see a change from the front oxygen sensor. I would say maybe you got an exhaust leak(most likely, time for a seafoam into the brake booster while looking for smoke leaking out of the exhaust) or somehow you bought the wrong one or the front oxygen sensor is bad. I suppose you could have a crap cat but that's the least likely.
drinksprite
Sep 14, 2018 12:00 PM
EJ8_Enthusiast
Sep 16, 2008 03:55 PM
Slammed_am
May 10, 2006 02:35 AM
LS stretch
Mar 17, 2004 11:57 AM
SmokeU
Nov 7, 2002 05:05 AM
