Removing Rubber O-ring on 90 teg caliper
Old Jul 7, 2006 | 01:56 PM
Fatty_1775's Avatar
Default Removing Rubber O-ring on 90 teg caliper
Does anyone know how to remove the large o-ring on a brake caliper? I need to remove it so I can get it powdercoated. Tried pullint it off and it ripped a bit. Can it be removed?
Old Jul 7, 2006 | 06:00 PM
lightcrx's Avatar
are you talking about the the piston dust cover?
if so theres a metal ring holding it in there, i sugest getting a rebuild kit and just rebuilding themwhen there done. the metal ring looks like the ring that holds the stearing wheel plastic(base of stearing wheel) togather
gl
-joseph
Old Jul 8, 2006 | 08:27 AM
Fatty_1775's Avatar
Default Re: (lightcrx)
and how do i remove those?
Old Jul 8, 2006 | 12:28 PM
Fatty_1775's Avatar
Default Re: (Fatty_1775)
is there a tutorial around to show how to remove the piston from the caliper?
Old Jul 8, 2006 | 03:14 PM
lightcrx's Avatar
if your going to rebuild just rip them out..... if not you nee a small flat head screwdriver or angled pick and pop it out, id suges rebuilding it tho
-joseph
Timothy Yhtomit
Mar 5, 2019 08:44 AM
vinuneuro
Apr 15, 2006 01:39 PM
fiebru1119
Nov 9, 2002 12:06 PM
Dr Pooface
Sep 15, 2002 09:38 PM
