Removing orings from GE Block
WTF do you guys use to remove orings from a golden eagle block? Ive been using a pick and it tends to "damage" the oring groove at the point where you start to peel it out.
Do you have any of these brass o-ring picks.
http://www.grainger.com/Grainger/items/4F418
I have some in my desk here at work.
We have bent the pick one a lot and it has not broken. The other one you could use as a chisel and try to get it under the o-ring.
I have also taken the small craftsman screwdriver, the one you can keep in your shirt pocket, and filed the blade down to make it into a chisel too.
-iLLuZioN-B18C1
Aug 4, 2004 06:19 AM
IloveNewt
Sep 19, 2003 07:59 AM
