removing a layer on an OEM headgasket?
Old Nov 17, 2002 | 08:54 PM
GreenD's Avatar
Default removing a layer on an OEM headgasket?
from the threads that ive searched, most people remove the middle layer. but when u look at the mugen headgasket,(like the one thats leaking in my car right now ) it looks like the top layer has been removed. the top layer also seems a bit thicker than the middle one.
does anyone have experiences w/ removing the top layer on a head gasket? will it seal ok? or, anyone that has removed the middle layer please share your experiences too. good or bad.
tia
chinese food + too much + =
Old Nov 18, 2002 | 11:06 AM
GreenD's Avatar
Default Re: removing a layer on an OEM headgasket? (GreenDestiny)
up
Old Nov 19, 2002 | 09:44 PM
GreenD's Avatar
Old Nov 20, 2002 | 10:46 AM
GreenD's Avatar
one more time
Old Nov 20, 2002 | 10:57 AM
raene's Avatar
From what I understand, the stock gasket uses spacers - those little raised round portions stuck all over it - to prevent overtightening of the gasket. By removing a layer from the headgasket, you won't be able to tighten past what those spacers allow, but you'll have removed the effective gasket seal. OK, that was a really bad explanation. Let's try ASCII art:
Original gasket:
Imagine that as a cross-section of your gasket. If you go ahead and remove the internal layer of that gasket, you'll end up with something like this, I'd think:
See the problem? Your gasket will probably blow out from the moment you install it.
[Modified by raene, 11:57 AM 11/20/2002]
Old Nov 20, 2002 | 12:17 PM
Colin's Avatar
Default Re: removing a layer on an OEM headgasket? (raene)
i thought those "spacers" you are referring to are just little rivet type things to keep the 3 layers together. in order to remove a layer don't you have to remove those little "rivets" (not sure what i should call them)....if so then you wouldn't have the problem you speak of.
Old Nov 20, 2002 | 12:27 PM
raene's Avatar
Default Re: removing a layer on an OEM headgasket? (91IntegGS)
You may be right. That was just a guess
I think it would be harder to align the gaskets if they weren't held together with handy rivets, however.
Old Nov 20, 2002 | 01:32 PM
CivicEK.PDX's Avatar
I used just the middle layer. been running it now for about 5 months and about 15k miles. Redlineing all day to 8600. Still holding.
Old Nov 21, 2002 | 09:03 AM
Kataku2K3's Avatar
Default Re: removing a layer on an OEM headgasket? (CivicEK.PDX)
Yea you do use the middle layer out of the OEM headgasket.... I don't do that because your chances of getting a good seal aren't as good.. I will never do this for that reason... If you want a high compression headgasket why not just with a Cometic... Peace
Old Nov 21, 2002 | 12:57 PM
Doogie Howser's Avatar
Default Re: removing a layer on an OEM headgasket? (JDMspecEG6)
i wouldnt recomened removing layers from a stock headgasket, if you lookin to bump the compression you should just buy a thinner headgasket
Old Nov 21, 2002 | 01:33 PM
T4crx's Avatar
I agree with jdmspecEG6 the best way to do it is with a thinner gasket. But if some one were doing it on the cheep I would think it would be best to use the 2 outside layers. I would also spray the layers down with Permatex Hi-Tac gasket sealant.
I do this even on stock head gaskets to help prevent leaks.
Old Nov 22, 2002 | 11:07 AM
GreenD's Avatar
Default Re: removing a layer on an OEM headgasket? (T4crx)
thanks guys.
any other input would be appreciated.
Old Nov 22, 2002 | 01:20 PM
Yes....DO NOT DO WHAT I DO. Only attempt it if your a pro.
Autoteggy
Oct 23, 2016 07:26 PM
crackerjacker006
Apr 8, 2007 09:17 PM
HondaGuy02
Jul 9, 2004 04:49 PM
gary201147
Feb 23, 2003 11:47 PM
biassj
Mar 6, 2002 12:10 PM
