Removing cable transmission case
Old Jul 5, 2003 | 02:24 PM
raene's Avatar
Default Removing cable transmission case
Please help guys, I'm stuck over here
Trying to pull the transmission case off a JDM S1 transmission. I need to unbolt the reverse idle gear and remove the c-clip from the main shaft before I can pull the case.
Problem is, I don't know where those are PLEASE can someone tell me/show me where?? I've been looking for almost 2 hours and I can't figure it out!! There's no info on the 'Net or on H-T that I can find, either!
*edit* This is the only info I have:
"There is also a bolt that holds the reverse idle gear in place. If you don't remove it then the upper case will hang up when you try to remove it. The reverse idle gear sits in a shift fork and you can't split the case. If you remove that bolt and the spread the C ring with two screw drivers it will open up no prob. Just pay attention to the location for everything. You will have to remove the shift forks and linkage to pull the main and counter shafts out. good luck "
Old Jul 5, 2003 | 03:03 PM
raene's Avatar
Default Re: Removing cable transmission case (raene)
aaaanyone?? Please, this is urgent
Old Jul 5, 2003 | 03:13 PM
raene's Avatar
OK I'm pretty sure the circled hole in the pic used to have the reverse idler gear retaining bolt... I pulled out that bolt. Now all I need is to find the mainshaft's retaining C-clip! Someone's gotta know!
Old Jul 5, 2003 | 03:20 PM
TREVER's Avatar
take out the plug in the bottom of the pic.
It comes out with a rachet
Old Jul 5, 2003 | 03:28 PM
raene's Avatar
Default Re: Removing cable transmission case (TREVER)
The one on my S1 transmission is stuck so tight, the hole is stripping out
But I can pull the one off an old D15 transmission without any force at all...
I see a C-clip behind the one on the D15, is that where the retaining C-clip is?!? If so I owe you a !!
Old Jul 5, 2003 | 03:51 PM
raene's Avatar
THANK YOU a thousand times over!!
Old Jul 5, 2003 | 05:18 PM
raene's Avatar
Next question
How do you hold the countershaft to keep it from turning while you undo the nut at the end of it??
Old Jul 5, 2003 | 05:39 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Next question
How do you hold the countershaft to keep it from turning while you undo the nut at the end of it??</TD></TR></TABLE>
impact gun
Old Jul 5, 2003 | 05:47 PM
raene's Avatar
Default Re: Removing cable transmission case (irev210)
How about if I don't have air tools?
Old Jul 5, 2003 | 06:06 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">How about if I don't have air tools? </TD></TR></TABLE>
Wood blocks and a vise.
Old Jul 5, 2003 | 06:12 PM
raene's Avatar
Default Re: Removing cable transmission case (Chiovnidca)
Well, I got it - I'm almost ashamed to say how Used a screwdriver wedged in between the mainshaft and the reverse idler gear... the straight-cut gears were the only ones that would hold the screwdriver. But it came out!
Now to put the tranny back together
twkdCD595
Jun 15, 2007 10:09 AM
SolTym
Oct 5, 2004 01:21 PM
B2FiNiTY
Jul 31, 2004 08:07 AM
t0p_sh0tta
May 3, 2004 09:53 PM
LsTurbo91
Jul 18, 2002 07:44 AM
