tranny drainplug?! first one to get it right wins!
stupid no brainer question by me but for some reason i cannon remember which one is the tranny fill plug? i know the drain plug but is the fill hole 1, 2 or 3? i used to work at an oil change for a year and cant even remeber! i know the tranny takes 1.6 or 1.7 L but cant even remeber the fill plug!
btw its a b16b!
Re: tranny drainplug?! first one to get it right wins! (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">DOh, fill plug is #2, i use number 3 to fill with.</TD></TR></TABLE>
wrong again
wrong again
Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe »</TD></TR><TR><TD CLASS="quote">you guys are confusing me!</TD></TR></TABLE>
its 1... 17mm. i think
Re: (hondachris1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 »</TD></TR><TR><TD CLASS="quote">I fill mine through the VSS, but I have a B-series tranny</TD></TR></TABLE>
lol so does he
lol so does he
Re: (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! »</TD></TR><TR><TD CLASS="quote">forsure its number 1</TD></TR></TABLE>
Re: (AdamB18C1EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK »</TD></TR><TR><TD CLASS="quote">
lol so does he </TD></TR></TABLE>Well then just fill it through the VSS and b done and its alot easyer to get to
hmm which ones have crush washers on them.... that would be telltale sign they are meant to be removed/serviced. #2 is a plug removed to access the upper case snap ring, and #3 I believe allows you to gain access to another snap ring or detent ball, I can't remember, but for sure #1 is the fill plug its always behind the axle. It appears you have a bad axle seal as well, unless you already repaired that.
Re: (Hondacivic90ed)
wtf is wrong with you people.
lol
the fill plug is number 1,
your suppose to fill it until fluid pours back out.
then that means its full.
I however use the vss because im lazy. i think its 2.8 quarts.
lol
Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">wtf is wrong with you people.
lol
I however use the vss because im lazy. i think its 2.8 quarts.</TD></TR></TABLE>
im pretty sure its 1.8-1.9 quarts.
lol
Not to be confused with "THE MAN"
#1 is the fill. And you had the drain labeled correctly. I think it is 1.9 qts of fluid. The other 2 plugs you had labeled are bolts that cover snap rings that hold the gear shafts I believe.
Re: (djsire)
lol</TD></TR></TABLE>
That's HT members working hard for you. You're better of referring to a $14 manual from autozone or pepboy. djsire is correct, bolt #1 is the filler bolt.
Re: tranny drainplug?! first one to get it right wins! (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! »</TD></TR><TR><TD CLASS="quote">1</TD></TR></TABLE>
its 1
its 1
Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business »</TD></TR><TR><TD CLASS="quote">ive used number 2 before. never had any problems. </TD></TR></TABLE>
Yeah, but your tranny was half full.
