reev limit for CTR cams
Old Jun 18, 2002 | 01:53 PM
LB CRX's Avatar
Default reev limit for CTR cams
my reev stops at 8000 right now. i have the CTR cams in a b16 motor with b16 valve train (i think thats how you spell it). i read that i need to swap over the type R valve train in order to raise the reev limit without having a problem. if i want to raise it to 9000, will i have a problem with my stock valve train or do i have to use the type R valve train? TIA
Old Jun 18, 2002 | 02:57 PM
Lsos's Avatar
Default Re: reev limit for CTR cams (LB CRX)
I'm pretty sure a b16a valve train would float at 9000rpms. With bigger cams, I'm almost 100% sure.
Old Jun 18, 2002 | 03:02 PM
MikeSarr_GSR's Avatar
Default Re: reev limit for CTR cams (Lsos)
Tru that. A good setup for CTR cams or any cams with up
to 12.5mm of lift AT THE VALVE is mainly a honda setup:
Yellow ITR Outer Springs x 16 $160
Portflow Stiffened Inner ITR Springs x 16 $80
Skunk2 Retainers x 16 $160
I use the Endyn oversized flat Black Nitrided SS exhaust valves (28.5),
$125 ITR intake valves with a 3 angle job $200 and what you see
above with CTR cams. I have overreved my engine more than once
with no conseqence and I am still on the GSR stock computer.
refs:
http://www.typerparts.com
http://www.portflow.com
http://www.importreview.com
http://www.theoldone.com
[Modified by MikeSarr_GSR, 12:05 AM 6/19/2002]
Old Jun 19, 2002 | 02:40 AM
PYITR821's Avatar
Default Re: reev limit for CTR cams (MikeSarr_GSR)
when you dynoed why did you only go to 5250 rpm? wouldn't you have made more horsepower if you went to 8000rpm? Especially with the CTR cams which are more aggressive.
Old Jun 19, 2002 | 01:45 PM
LB CRX's Avatar
Default Re: reev limit for CTR cams (JUNtypeR)
i did take it up to 8000...then it cut off. i wouldve put a chip in to reev higher, but i was scared somethin would go wrong since i still have the b16 valve train.
Old Jun 19, 2002 | 01:59 PM
Were you talkin to me? hehe...
CTR cams/Sk2 gears:
Stock GSR everything but head and gears
slightly modified, however full cat and muffler
+4ex in crank deg, +2in in crank degrees
@ 20BTDC (18BTDC at 0,0, at 0,2 +
2 BTDC timing and valve opening)
163 whp at @7600 rpm
125 tq at @7400 rpm
122 at 5250 < this is the whp/tq crossover point.
my next mods will be: $3000
JDM final drive 4.785
Honda Type-R LSD
JDM DC 4-1
Test pipe
Tanabe 2.5" catback
Hondata or AEM Standalone with
Skunk2 Intake and 270cc injectors.
B&M ADJ FPR kit
re-tune cams, chip computer.
8400 redline
Fast Brakes Type R conversion
Konis for the rear, upgraded upper swaybars,
urethane cups and bushings, shift kit,
275lb/in static springrate for rear
want: 185/140 and 130 at 5250, 20mpg
daily driven to high 13s
my goal is to tune for strong midrange
while gaining upper RPM and to make
VTEC POP. GSRs dont normally do that...
then my extended plan: $4000
1956cc high revving NA GSR
8800rpm, 84.5mm bore on stock GSR crank
Forged pistons and rods, sleeved block
11.5:1 pistons, ARP head studs and rodbolts
upgraded high compression rings
endyn prepped ITR oil pump
84.5 bore 2 layer B18C1 head gasket
266_12.5/260_12 cams
headwork flowed for 2.0 and high revs
.5 oversized Endyn SS flat valves
310cc RC injectors
retain 2.5" exhaust with 3" catback
NA goal: 225/155 with 140 at 5250 18mpg
daily driven to low 13s on street tires
16" gunmetal volk racing LE-37Ts w/ 215/50/ZR16 Potenza SO3s
type r rear wing to go with my OEM GSR
full body kit
keep it a stocky looking corvette killer
I LOVE MY TEG
next...
10:1 pistons... 1 bar... darkside... oooh yes
OOOOOOOOOHHhhhhhhhhh YES!
[Modified by MikeSarr_GSR, 11:23 PM 6/19/2002]
Old Jun 23, 2002 | 01:08 PM
Balrog's Avatar
New User
mike
you are the man!
Old Jun 23, 2002 | 03:41 PM
bryant's Avatar
You should be glad you cant go to 9k RPM yet. The stock B16a valves, and springs cant take it. They are too soft. you would fore sure get valve float. Save your money up for stiffer valves and springs and retainers and then get a the chip. The CTR cams only make power a little past 8.5K and then die off anyway. But witht the stiffer valves and such, you should be okay for the 9k RPM.
Old Jul 2, 2002 | 10:31 PM
Default Re: reev limit for CTR cams (CR-X)
I bet you will reEEEEEEEALLLLY
like this site then...
http://www.importreview.com/reviews/...n3VStyper.html
CTR/ITR kick sooo much *** for acceleration... on a budget
also read this:
factors in creating acceleration: enter the mind of Tuan
http://www.hondalife.com/articles/factorsinaccel.htm
cheers...
[Modified by MikeSarr_GSR, 7:32 AM 7/3/2002]
SPOON_FED_DC_2
Apr 4, 2005 09:33 PM
brixity
Feb 7, 2005 03:13 AM
Dammit_Dan_954
Nov 22, 2003 12:27 PM
klnteg
19
Nov 18, 2003 01:48 PM
ImportHatch
Jan 25, 2002 12:18 AM
