redline and vtec point on lsvtec
Old Jun 11, 2005 | 11:29 PM
bOOsTiNSoHcVtEc's Avatar
Default redline and vtec point on lsvtec
stock b18b block
b16 head
gsr cams
i/h/e
Where should i set my vtec point and redline? What do you guys set it at for your lsvtec's? And whats your setup?
Old Jun 12, 2005 | 05:48 AM
hondaguyef's Avatar
Default Re: redline and vtec point on lsvtec (bOOsTiNSoHcVtEc)
*A dyno will be needed to figure both of these accurately but, I can give you my .02*
1) GSR cams vtec @ 4700
2) I would set the limiter @ no higher than 8K due to the stock B18b bottom end(power won't be made much higher anyway). You'd be pissed if a rod bolt said, "peace out". So, be smart and safe.
Phil
Old Jun 12, 2005 | 07:15 AM
Default Re: redline and vtec point on lsvtec (hondaguyef)
thanks man.. anyone else with an opinion? maybe someone with a similar setup?
Old Jun 12, 2005 | 01:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">thanks man.. anyone else with an opinion? maybe someone with a similar setup?</TD></TR></TABLE>
Old Jun 12, 2005 | 07:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">thanks man.. anyone else with an opinion? maybe someone with a similar setup?</TD></TR></TABLE> ^
Old Jun 12, 2005 | 08:08 PM
90REDHATCH's Avatar
I am a scammer!
I would agree with him due to the stock bottom end and just keep an eye on the head
Old Jun 12, 2005 | 08:24 PM
Default Re: redline and vtec point on lsvtec (PhoShizzle-Tech)
so 4700 and 8000?
Old Jun 12, 2005 | 08:27 PM
PrettyLude's Avatar
i just went to the dyno not too long ago with a ls/vtec and it stops making power at 7500 rpm
Old Jun 12, 2005 | 08:29 PM
Default Re: (PrettyLude)
whats your setup?
Old Jun 13, 2005 | 05:53 AM
dohcdelsol93's Avatar
Default Re: (bOOsTiNSoHcVtEc)
i'm going to be putting my ls/vtec turbo on the dyno soon, adding a turbo extends the torque/hp range but i'm still planning on cutting it off around the 7800-8000 rpm range. I'll be engaging vtec some where between 4300-4700 rpms depending on the dyno results. if you engage vtec too early you'll actually drop in hp before it pics back up
Old Jun 13, 2005 | 11:31 AM
SpeedyEk9's Avatar
Default Re: (dohcdelsol93)
i had my lsvtec since 01
during the first year and a half it was revved to 8400 gsr ecu
then i got and itr ecu then it revved until 8700
and now i have a kenji with 8900
and it gets revved up there to the limit all the time
i also have ctr cams in it
with the chipped ecu
and a completely stock bottom end
its up to u where u want to rev at
i had complete faith im my mecanic so i rev the hell out of the motor
just make sure ur up to par with your maintence
i have new itr water pump, timing belt. and oil pump
Old Jun 13, 2005 | 03:38 PM
Default Re: (SpeedyEk9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedyEk9 &raquo;</TD></TR><TR><TD CLASS="quote">i had my lsvtec since 01
haha nuts! i think ill just stick with vtec @ like 4800 and redline at 7800.. sound good? wheres your vtec point at?
Old Jun 13, 2005 | 06:03 PM
slomofo's Avatar
GDD Member
I'd go for 4700VTEC, 7500 limit
Old Jun 13, 2005 | 06:15 PM
Default Re: (slomofo)
why are you guys suggesting vtec at 4700? is there a reason behind this?
Old Jun 13, 2005 | 06:21 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">why are you guys suggesting vtec at 4700? is there a reason behind this?</TD></TR></TABLE>
Because the low cam lobe will start to fall off(power) a little before that point.
Phil
Old Jun 13, 2005 | 06:31 PM
Default Re: (hondaguyef)
genius'!
Old Jun 21, 2005 | 05:04 PM
Honduh Tooner's Avatar
my vtec comes in at 5300 and i rev limit at 10K, and yes i hit it. (take it i spent over 4K in building the **** out of it and i dynoed it still makin hp up till 9200) next time im at the dyno i'll be sure to video it this time
Old Jun 25, 2005 | 12:06 AM
HyperX's Avatar
Default Re: (Honduh Tooner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honduh Tooner &raquo;</TD></TR><TR><TD CLASS="quote">my vtec comes in at 5300 and i rev limit at 10K, and yes i hit it. (take it i spent over 4K in building the **** out of it and i dynoed it still makin hp up till 9200) next time im at the dyno i'll be sure to video it this time</TD></TR></TABLE>
any headwork? i am just curious. and what cams are you using?
Old Jun 25, 2005 | 07:29 AM
LSVTEC 91 Civic's Avatar
Banned
My VTEC kicks in at 5600, dyno sheet looked OK so I didn't **** with it. I keep the redline at 8-8100 because I stop making power at around 7900-8000. Running a set of billet webcams.
Old Jun 25, 2005 | 08:10 AM
hondaguyef's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">My VTEC kicks in at 5600, dyno sheet looked OK so I didn't **** with it. I keep the redline at 8-8100 because I stop making power at around 7900-8000. Running a set of billet webcams.</TD></TR></TABLE>
Key words were: GSR cams.
Phil
Old Jun 25, 2005 | 08:31 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Key words were: GSR cams.</TD></TR></TABLE>
Thanks!!!
Old Jun 25, 2005 | 12:48 PM
Default Re: (HyperX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperX &raquo;</TD></TR><TR><TD CLASS="quote">
any headwork? i am just curious. and what cams are you using?</TD></TR></TABLE>
5 angle valve job, port and polish, skunk 2 sodium nitrate coated valves, titanium retainers, dual titanium springs, jun 3 intake cam, skunk 2 stage 2 exhaust cam, brass valve guides
dirtyharryhatch
11
Jun 20, 2008 09:57 AM
gsrvtec2
Sep 28, 2005 07:09 PM
Slava.
Jan 7, 2004 05:47 AM
SleepnCiViC
Jan 4, 2004 04:21 PM
90JPRCRX
33
Dec 27, 2003 06:40 PM
