redline and vtec point on lsvtec
stock b18b block
b16 head
gsr cams
i/h/e
Where should i set my vtec point and redline? What do you guys set it at for your lsvtec's? And whats your setup?
b16 head
gsr cams
i/h/e
*A dyno will be needed to figure both of these accurately but, I can give you my .02*
1) GSR cams vtec @ 4700
2) I would set the limiter @ no higher than 8K due to the stock B18b bottom end(power won't be made much higher anyway). You'd be pissed if a rod bolt said, "peace out". So, be smart and safe.
Phil
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc »</TD></TR><TR><TD CLASS="quote">thanks man.. anyone else with an opinion? maybe someone with a similar setup?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc »</TD></TR><TR><TD CLASS="quote">thanks man.. anyone else with an opinion? maybe someone with a similar setup?</TD></TR></TABLE> ^
i'm going to be putting my ls/vtec turbo on the dyno soon, adding a turbo extends the torque/hp range but i'm still planning on cutting it off around the 7800-8000 rpm range. I'll be engaging vtec some where between 4300-4700 rpms depending on the dyno results. if you engage vtec too early you'll actually drop in hp before it pics back up
i had my lsvtec since 01
during the first year and a half it was revved to 8400 gsr ecu
then i got and itr ecu then it revved until 8700
and now i have a kenji with 8900
and it gets revved up there to the limit all the time
i also have ctr cams in it
with the chipped ecu
and a completely stock bottom end
its up to u where u want to rev at
i had complete faith im my mecanic so i rev the hell out of the motor
just make sure ur up to par with your maintence
i have new itr water pump, timing belt. and oil pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedyEk9 »</TD></TR><TR><TD CLASS="quote">i had my lsvtec since 01
haha nuts! i think ill just stick with vtec @ like 4800 and redline at 7800.. sound good? wheres your vtec point at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc »</TD></TR><TR><TD CLASS="quote">why are you guys suggesting vtec at 4700? is there a reason behind this?</TD></TR></TABLE>
Because the low cam lobe will start to fall off(power) a little before that point.
Phil
Phil
my vtec comes in at 5300 and i rev limit at 10K, and yes i hit it. (take it i spent over 4K in building the **** out of it and i dynoed it still makin hp up till 9200) next time im at the dyno i'll be sure to video it this time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honduh Tooner »</TD></TR><TR><TD CLASS="quote">my vtec comes in at 5300 and i rev limit at 10K, and yes i hit it. (take it i spent over 4K in building the **** out of it and i dynoed it still makin hp up till 9200) next time im at the dyno i'll be sure to video it this time</TD></TR></TABLE>
any headwork? i am just curious. and what cams are you using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">My VTEC kicks in at 5600, dyno sheet looked OK so I didn't **** with it. I keep the redline at 8-8100 because I stop making power at around 7900-8000. Running a set of billet webcams.</TD></TR></TABLE>
Key words were: GSR cams.
Phil
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">Key words were: GSR cams.</TD></TR></TABLE>
Thanks!!!
Thanks!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperX »</TD></TR><TR><TD CLASS="quote">
any headwork? i am just curious. and what cams are you using?</TD></TR></TABLE>
5 angle valve job, port and polish, skunk 2 sodium nitrate coated valves, titanium retainers, dual titanium springs, jun 3 intake cam, skunk 2 stage 2 exhaust cam, brass valve guides
90JPRCRX
33
Dec 27, 2003 06:40 PM
