recomendation for self-bleeding brake kit?
Old Sep 22, 2004 | 10:46 PM
huyvu90's Avatar
Default recomendation for self-bleeding brake kit?
i'm not a pro so i'm not going to use it everyday thus no need for expensive ones
Old Sep 22, 2004 | 11:03 PM
Sack Master's Avatar
Default Re: recomendation for self-bleeding brake kit? (huyvu90)
Russell speed bleeders. Call summit racing equipment. They are like $9.88 a pair. PN RUS-639610. At least for most civics and integras. It makes it damn easy to bleed your brakes by yourself.
Old Sep 23, 2004 | 05:17 AM
JimBlake's Avatar
Default Re: recomendation for self-bleeding brake kit? (Sack Master)
I got them & they worked pretty good. But then 2 years later they were corroded & then they didn't work work so hot. So consider where you live & how much salt they use on the roads...
Old Sep 24, 2004 | 07:54 PM
huyvu90's Avatar
I was thinking of a hand pump type self bleeder that way I can also use it to do vacumn diagnostic.
Old Sep 24, 2004 | 08:27 PM
JimBlake's Avatar
Default Re: (huyvu90)
I've got a mityvac too. But using it on brakes it tends to suck air thru the threads of the bleeder screw. That doesn't really put air in the system but it's still annoying. You still have to finish up with someone pumping the pedal.
Supra
Jul 13, 2005 09:55 PM
1hottEG6
12
Jun 26, 2004 01:39 AM
blaze1987
May 20, 2004 04:07 AM
wessieball
Aug 4, 2002 07:47 PM
JSIR
Feb 10, 2002 05:04 PM
