rebuilding motor..!!!!headgasket!!
Old Jun 22, 2006 | 10:58 PM
VRD^suzie's Avatar
Default rebuilding motor..!!!!headgasket!!
okay guys..i recently rebuilt my b18b..basically a total rebuild..new gaskets and rings bearings...all stock..motor has been setting for a while now...i have not run the motor yet after the rebuild so its been sitting for quite a while now..okay..lets get to the point..i just bought some new pistons and rods for it..i was wondering if i can stilll reuse the head gasket..i mean its has no miles on it..never been under compression..its a totally new headgasket..so the question is..do i have to get a new one or can i reuse it..thanks guys
Old Jun 23, 2006 | 10:42 AM
VRD^suzie's Avatar
Default Re: rebuilding motor..!!!!headgasket!! (payo_vang)
help
Old Jun 23, 2006 | 11:23 AM
Jago's Avatar
if you torqued the head bolts on the head then you will need a new one
Old Jun 23, 2006 | 12:25 PM
unknown0001's Avatar
Default Re: rebuilding motor..!!!!headgasket!! (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">if you torqued the head bolts on the head then you will need a new one</TD></TR></TABLE>
not correct
You can re-use the head gasket. I've done it multiple times and no problem.
If you want to be safe, spray the head gasket with the copper spray for headgaskets to help it seal better
&lt;---- currently running a b18b with a oem 1-layer reused head gasket without problems
Old Jun 26, 2006 | 03:28 PM
VRD^suzie's Avatar
Default Re: rebuilding motor..!!!!headgasket!! (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">
not correct
&lt;---- currently running a b18b with a oem 1-layer reused head gasket without problems</TD></TR></TABLE>
thats what i was thinking too..but using honda bond instead..more input please!!
Old Jun 26, 2006 | 03:53 PM
NJIN BUILDR's Avatar
No problem using it over again.I would install it dry or use copper spray,but not Hondabond.
Old Jun 26, 2006 | 11:59 PM
miller's Avatar
Default Re: rebuilding motor..!!!!headgasket!! (NJIN BUILDR)
there is nothing wrong with using the gasket over, the one thing i suggest when using copper spray is to take a Q-tip with alcohol and clean the leading edges of the oil passages cut in the headgasket clean of all copper spray.
Old Jun 27, 2006 | 10:15 AM
VRD^suzie's Avatar
Default Re: rebuilding motor..!!!!headgasket!! (miller)
cool..thanks guys..
soysauce90CRXsi
Nov 19, 2008 05:15 PM
93baggedcivic
Dec 20, 2007 03:41 PM
austincrx
Sep 7, 2006 09:49 AM
chop suey
Nov 9, 2004 05:47 PM
petrv
Apr 12, 2004 12:30 PM
