Rebuild a 4cyl as a 3cyl?
Old Jun 1, 2009 | 09:25 PM
imzjustplayin's Avatar
Default Rebuild a 4cyl as a 3cyl?
I noticed that the geo metro has a 3 and 4 cyl version of its car, but was wondering how you adjust the cylinder's degrees of separation. Like 6 cylinder engines are more smooth because there is always a cylinder firing every 60 degrees. I was curious about the idea of taking a D15 series engine and simply removing the piston and rod, valves, etc. for one of the cylinders. In order to make the engine not run unbalanced, you'd need to adjust the other cylinders so that they come up every 120 degrees and change the valve timing, right? Is the crankshaft like the camshaft in that it's premilled to a specification that allows the pistons to come up and down after a given time? If so, would this mean you'd need a new crankshaft as well? Or is it possible to simply remove the right piston, therefore making each piston come up every 120 degrees?
Old Jun 2, 2009 | 06:37 AM
92redhatch's Avatar
Default Re: Rebuild a 4cyl as a 3cyl?
YOUR JOKING RIGHT?
Paul Kane
K Series
Jun 8, 2015 05:49 PM
ludesleep
Dec 18, 2007 09:18 AM
EJ8 GSR-T
Nov 21, 2006 05:16 PM
93b16delsol
Oct 22, 2005 09:47 PM
seako_916
May 19, 2004 08:52 PM
