reatiners diy please
Old Mar 26, 2008 | 11:04 PM
02vtecsir's Avatar
Default reatiners diy please
trying to change retainers without dropping the valves and not removing the head, jdm b18c
Old Mar 27, 2008 | 08:39 AM
KENetics1's Avatar
Default Re: reatiners diy please (02vtecsir)
I believe your looking for this tool. I know snapon make them but there are other companies out there for less.
Old Mar 27, 2008 | 09:36 AM
02vtecsir's Avatar
how about a backyard special
Old Mar 27, 2008 | 10:48 AM
Flashmn's Avatar
Default Re: (02vtecsir)
well theres a cheap one on ebay, but its gonna be sllllooooow and also you dont want any backyard specials, those will only cause you grief.
Old Mar 27, 2008 | 04:44 PM
arc_55's Avatar
Default Re: (Flashmn)
you need a 14mm spark plug adapter with a air line fitting on it. You could adapt a compression tester into something like this and i beleive they sell them aswell. You could also adapt a pressure regulator onto it aswell to regulate the amount of air pressure. Remove the camshafts and timing belt and begin to remove the valves. The compressed air will hold the valves up and ensure they won't drop. Be careful not to loose the keepers!!! I have done this before when removing and installing new valve seals on a d-series, but i didn;t have to remove the camshaft.
zeroon2
Sep 25, 2010 05:46 AM
averyvm
Apr 7, 2008 06:57 PM
averyvm
Oct 23, 2006 05:35 PM
GreenD
Feb 4, 2003 09:36 PM
GQ 05YellowEVO8
Jan 25, 2002 12:53 PM
