Reasons for overheating on '90 RS
Old Jul 12, 2005 | 02:38 PM
NewtwoHondas's Avatar
Default Reasons for overheating on '90 RS
My GF just stopped by and her coolant is boiling in the reservoir.. the fan on the drivers side is currently on. I am not familiar with how hondas work but she was driving around with the AC on for a little bit today and it is almost 100 out. I would assume that when you use the AC the fan on the passenger side should be on all the time? Is this not right?
Once it cools down I am going to check the coolant to see if I can tell what mixture she is running and see if she needs a coolant flush. Other than that I don't know what else I could do to fix her car from overheating while running AC if anyone has any ideas.
Old Jul 12, 2005 | 03:13 PM
gATOr65's Avatar
Default Re: Reasons for overheating on '90 RS (NewtwoHondas)
flush the coolant sys. then see what happens. if there is a milky kinda residue coming out of the radiator its more than likely a blown head gasket. same thing was happening to my gsr trurns out it was the head gasket. i could run it for a bout 5 min then the the water in the res. would boil. but goodluck
Old Jul 12, 2005 | 05:20 PM
Default Re: Reasons for overheating on '90 RS (gATOr65)
I doubt her head is warped because the needle only got 3/4 between the way from c to h. Prolly just needs a coolant flush I am thinking but we will see.
Old Jul 12, 2005 | 08:19 PM
FIGARILA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NewtwoHondas &raquo;</TD></TR><TR><TD CLASS="quote">My GF just stopped by and her coolant is boiling in the reservoir.. the fan on the drivers side is currently on. I am not familiar with how hondas work but she was driving around with the AC on for a little bit today and it is almost 100 out. I would assume that when you use the AC the fan on the passenger side should be on all the time? Is this not right?
Once it cools down I am going to check the coolant to see if I can tell what mixture she is running and see if she needs a coolant flush. Other than that I don't know what else I could do to fix her car from overheating while running AC if anyone has any ideas. </TD></TR></TABLE>
gator 65 has a good point , if that checks out try
-checking fan switch relay
-check the temp sending unit
if it was as hot as you described both fans should be on not just the AC one (driver side)
h2392si's Avatar
first do a flush, next change the thermostat, radiator cap, and add new coolant.very easy and simple to do.try it.
Old Jul 13, 2005 | 12:01 AM
will see what I can do this week, drove the car with AC on tonight in 80* weather and it runs awesome and was not overheating.... have to double check because I don't think both fans are running with AC and with stop,go traffic that is why she got it so hot. Will post up what I find in case anyone interested.
verma
Honda S2000
Feb 8, 2018 03:30 PM
Aaron Cayabyab
36
Jun 14, 2012 09:20 PM
BlackShingo
May 6, 2010 03:56 PM
Dor
13
Nov 7, 2005 02:50 AM
vinuneuro
Jun 22, 2005 10:16 PM
