rear rotor question
Old Sep 23, 2002 | 08:15 AM
civbeater90's Avatar
Default rear rotor question
if i have no fluid in the lines it won;t squeeze the caliper right?
Old Sep 23, 2002 | 08:22 AM
letsride's Avatar
Default Re: rear rotor question (civbeater90)
Correct!
Old Sep 23, 2002 | 09:09 AM
martini's Avatar
I noticed your post in the road racing forum.
The ebrake is mechanical, not hydraulic. It doesn't need fluid at all. If you pull the ebrake with no fluid in the lines, it will STILL engage the piston.
Old Sep 23, 2002 | 11:23 AM
Default Re: rear rotor question (martini)
are you postive?i know they squeeze with rear drums but i have swapped to rear rotors and i can;t get tehm to squeeze.so i;'m wondering if it needs fluid.
Old Sep 23, 2002 | 01:55 PM
martini's Avatar
Did you change out your cables (or readjust them, or anything like that) after doing the swap?
The drum cables are different than the disc cables. I think you need to replace them..
Old Sep 23, 2002 | 04:58 PM
ok figured out the problem ,one of the calipers needed to be adjusted.
nycpatron
Sep 6, 2016 06:58 AM
xiLLtegRax
Mar 22, 2006 07:48 PM
93egsi
Jul 14, 2005 08:48 AM
spender1326
Jun 6, 2005 11:54 AM
DJ0820
Apr 28, 2004 11:12 AM
