Rear disk coversion help
Old Sep 22, 2002 | 06:05 PM
b16EF's Avatar
Default Rear disk coversion help
I have a 1991 Honda Civic STD, I am converting it to disk in the rear, I am using 1993 integra LS trailing arms etc. and and putting larger disks up front, probably use the knuckles and rotors etc from a 1996 Civic EX, what should I use for a master cylinder, will the STD one work, or should i switch it with another one, if so, which should i use, i also have a MC from a 1988 CRX Si, i'm not sure if this will work either i just had it with some spare parts. Any help would be great thanks
Old Sep 22, 2002 | 06:10 PM
Jared's Avatar
Default Re: Rear disk coversion help (b16EF)
88 crx si master is probably the same as what you have. only the 90-91 crx si had rear disc. i would just change out the proportioning valve to the integra model first and go from there depending on what your pedal feels like.
superhatchbackbros
May 12, 2009 12:03 AM
crxhftosi
Jan 30, 2005 10:13 PM
HT Chaplain
14
Aug 14, 2003 08:20 PM
spun Vtec
Feb 10, 2003 03:56 PM
allmotorEG-SI
Oct 24, 2001 05:06 PM
