Random Revving in nuetral
Old Nov 9, 2010 | 08:36 AM
chrisff521's Avatar
Default Random Revving in nuetral
I have a h22 swapped in an integra. The swap was done cleanly and the right way but anyways, When im driving and then come to a stop, the motor keeps revving from 1k to 2.5k RPM repeatedly and eventually will stop after 3-10 revs. At first it used to do it only when you would drive a few feet in traffic and when u put it in neutral the car would rev up about 1k RPM higher and then go back down to idle. It doesnt do it when I first start the car. And I adjusted the TPS thinking it wasnt set correctly because the two screws were loose and I set it to .49V and now it Revvs by itself more often now. I dont know if having a blox throttle body affects anything. And I have a stock p28 unchipped/untuned yet. IDK if those two things will affect that.
Old Nov 10, 2010 | 09:30 AM
chrisff521's Avatar
Default Re: Random Revving in nuetral
Bump.....
Old Nov 10, 2010 | 11:27 AM
2k.civic.si's Avatar
what ecu are you using?
Old Nov 10, 2010 | 11:31 AM
chrisff521's Avatar
I think its a stock p28.
Old Dec 8, 2010 | 02:37 PM
chrisff521's Avatar
It's actually a chipped p28 and now I'm thinking its a vacuum leak because it idles high and revs from 1k to 2.5k still.
Old Dec 9, 2010 | 08:18 AM
chrisff521's Avatar
Is it possible to find a vacuum leak the same way we find boost leaks with the boost leak tester. pressurize through the throttle body and then listen for leaks?
Old Dec 10, 2010 | 10:22 AM
chrisff521's Avatar
What does it mean if my car only starts idling like that when the car warms up. When its cold it doesnt do it.
Old Dec 11, 2010 | 06:01 AM
Dren's Avatar
I have the same problem and I think it's air in the cooling system. I had to pull a coolant line and mine has had the same idle issue as yours since then. I've bled it a few times but I know I haven't gotten all the air out yet.
Spoon84
Jun 20, 2009 08:17 AM
preludedriva
Dec 22, 2006 01:12 AM
KNIVES
Apr 7, 2004 05:24 PM
Combustion Contraption
Apr 4, 2004 09:29 AM
