R head using B16A???
Old Jul 14, 2006 | 02:52 AM
JdmLub's Avatar
Default R head using B16A???
ive tried to look this up (cuz i know some one already covered it) what exactly do u do to the head to make it a type-r.. smooth out the combustion chamber port/polish in the valves, use itr cams/valves/springs/etc..
but does anybody know the exact amount u would take out.. cuz i know a B16 head in the combustion chamber, the angel of the valve when it opens the clearence is 60/45/forgot the rest angel, and a type-r is a 65/45/forgot the rest angel of air flow... just wondering if anybody know's the real mathematical reasoning in this?? i would like to know.. not just for mad Vtec y0!!
Old Jul 14, 2006 | 04:19 AM
JdmLub's Avatar
Default Re: R head using B16A??? (JdmLub)
maybe i explained it wrong... lets try, if u take ur head to a machine shop, what do u tell the guy to cut off to make it resemble a type-r head?? from there i can at least match up specs and see what gets cut/milled/polished....
Old Jul 14, 2006 | 08:40 AM
JdmLub's Avatar
so what i have read the the net is wrong?? or nobody understands the question?? or does nobody know the answer??
Old Jul 14, 2006 | 09:33 AM
Katman's Avatar
Honda lightly modifies an ITR head.
The intake + exhaust ports are lightly ported & polished.
The intake valves have a tapered design, making them slightly lighter and allow a tad more air intake. The exhaust valves are just stock GSR valves.
The intake valve springs are stiffened, exhaust springs are stock GSR.
The rocker arm assembly....mainly rocker pads...are spec'd out for ITR cam use.
Combustion chamber isn't touched.
This same treatment is found on the CTR head too.
check out this link when you get a chance:
http://www.hondanews.com/CatID...ves=t
Old Jul 14, 2006 | 11:14 AM
JdmLub's Avatar
Default Re: (Katman)
u r the man!! i knew some body had to know.. thanks alot mang
Old Jul 14, 2006 | 12:14 PM
Katman's Avatar
Default Re: (JdmLub)
no prablem
JdmLub
Jul 14, 2006 01:47 AM
Sketch_hs
22
Jun 22, 2005 04:25 PM
corgiat
Sep 9, 2003 12:17 AM
vtec69
Mar 4, 2002 09:18 PM
vtec69
Mar 4, 2002 10:59 AM
