Quick questions about OBD1 engine into OBD0 car
Old Aug 19, 2004 | 02:01 PM
0ptimus prime's Avatar
Default Quick questions about OBD1 engine into OBD0 car
Alright guys, this is my first time swapping an obd1 engine into an obd0 car. I have some questions...
First off, we've already purchased the obd0-1 conversion harness so that we can use the P06 (obd1 DX) ecu. OK my question is......What harness do i use on the actual engine?
Do i use the CRX HF harness (obd0) on the OBD1 engine? Or do i use the DX engine harness (obd1).
If i use the DX harness, how do i get it to fit at the shock tower? I know the connections are different.
If i use the HF harness, do all of the sensors and plugs go in the same on the OBD1 engine?
Also, for the ECU pigtail, do i wire the bare wires to the firewall side of the shock tower connections?
Thanx for some input.
Old Aug 19, 2004 | 02:25 PM
Default Re: Quick questions about OBD1 engine into OBD0 car (0ptimus Prime)
common you bastages...
Old Aug 19, 2004 | 04:00 PM
hondaguyef's Avatar
use the HF harness
Use the obd0 injectors
Everything else will plug right in. I have a 95 b18b into an 89' hatch. I am running obd0 b18a injectors. everything else is from the 95' teg though. Also to use the obd0-obd1 harness you must use a 4 wire o2 and an obd1 dizzy. Hope this helped.
Phil
Old Aug 19, 2004 | 04:21 PM
Default Re: Quick questions about OBD1 engine into OBD0 car (hondaguyef)
yea it helped big time, thank you man!
Ok and another Q.... does the conversion harness connect behind the firewall? Like from the ECU to the shocktower?
Old Aug 19, 2004 | 04:57 PM
hondaguyef's Avatar
No, one side plugs into the obd0 side ecu plugs and the other to the p28. Very simple
Old Aug 19, 2004 | 05:37 PM
what about all the loose wires the hness comes with? Watch i'll get a pick
Old Aug 19, 2004 | 06:13 PM
hondaguyef's Avatar
I can walk you through it . Is it boomslang or blown90's harness?
Old Aug 19, 2004 | 08:54 PM
it's actually Lightning motorsport's harness
Old Aug 20, 2004 | 02:20 AM
hondaguyef's Avatar
e-mail me the directions that came w/ the harness. I have never used that one before but, I am sure I can help.
Phil
Old Aug 20, 2004 | 07:23 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">what about all the loose wires the hness comes with? Watch i'll get a pick</TD></TR></TABLE>
Those wires are for stuff that obd1 has but your obd0 didnt.. Like vtec wires, knock sensor, o2 sensor heater, ect..
Old Aug 20, 2004 | 11:24 AM
hondaguyef's Avatar
Default Re: Quick questions about OBD1 engine into OBD0 car (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Those wires are for stuff that obd1 has but your obd0 didnt.. Like vtec wires, knock sensor, o2 sensor heater, ect..</TD></TR></TABLE>
TRUE^^^^^^^^^^^^
Old Aug 20, 2004 | 06:58 PM
Blown90hatcH's Avatar
Why is it that people who buy harnesses from me have all the questions answered by me?
As for your post, if your questions have not been answered....let me know.
Old Aug 21, 2004 | 05:35 AM
hondaguyef's Avatar
Default Re: Quick questions about OBD1 engine into OBD0 car (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Why is it that people who buy harnesses from me have all the questions answered by me?</TD></TR></TABLE>
Because, You are the ****!!!!!
Old Aug 21, 2004 | 08:03 AM
PHiZ's Avatar
Here is some additional info: https://honda-tech.com/zerothre...52074
-PHiZ
Old Aug 22, 2004 | 08:50 AM
Default Re: Quick questions about OBD1 engine into OBD0 car (PHiZ)
thank you phiz....but i can't seem to find the answer to a new problem that has came up - maybe you know?
The OBD0 motor mount for the d-series does NOT fit the new D series engine (obd1). It angles off too far to the right and won't fit. The obd1 engine mount fits on the engine, but is too fat for the CRX driver side bracket, what am i supposed to use?
Old Aug 22, 2004 | 04:38 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">thank you phiz....but i can't seem to find the answer to a new problem that has came up - maybe you know?
The OBD0 motor mount for the d-series does NOT fit the new D series engine (obd1). It angles off too far to the right and won't fit. The obd1 engine mount fits on the engine, but is too fat for the CRX driver side bracket, what am i supposed to use?</TD></TR></TABLE>
Use the mount bracket from the obd0 engine as well as the obd0 mount. The obd1 mount bracket is not compatible.
Old Aug 22, 2004 | 06:52 PM
yea i know i had to figure that out the hard way
boomslang
Dec 6, 2010 09:37 AM
AllmotorGSReg
Sep 23, 2008 11:40 AM
Honda_Fanatic
Oct 29, 2007 08:52 AM
0ptimus prime
Aug 20, 2004 09:14 AM
0ptimus prime
Aug 19, 2004 02:59 PM
