NEED HELP!! Rear suspension on 98 ex PLEASE!!!!
Old Aug 22, 2004 | 05:20 PM
rotory20's Avatar
Default NEED HELP!! Rear suspension on 98 ex PLEASE!!!!
Ok here the deal got the front of the car done no problems.
Rear suspension trying to take the rear bolt from bottom, using everything under the sun 4; 12 in bars attached to the wrench. and then the air gun....
Sheer the head clean off. ok cool the the strut out now there is a cylinder of metal.. tried using easy out...snaped that off too into the bolt thats stuck in there.
Back to the start now....
If I just torch the bushing in there will the whole thing come out?
or am I just wasting my time..?
What can I do...
Old Aug 22, 2004 | 06:18 PM
Squirtin EGsr
Guest
Posts: n/a
yea that happens alot... umm you have to take the whole lower controlle arm off and use a press to press the whole bushing out... the bushing has a ring on it... so if you do burn the bushing out its just the rubber so the ring will still be in there that needs to be pressed out... good luck let me know how it turns out! if you need more help let me know!!!
Old Aug 22, 2004 | 07:03 PM
rotory20's Avatar
Default Re: (RiceRocket12s)
you have no idea how much i appreciate that bro..!!!!!!
Ill be taking care of that as soon as I can get to the hobby shop...
redlinerevolution
May 2, 2007 12:03 PM
juniordc2
Suspension & Brakes
11
May 19, 2006 03:37 PM
mattharper
Dec 8, 2003 08:33 PM
ITR981002
Sep 4, 2003 06:58 PM
hotrodder79
Aug 12, 2003 03:44 PM
