Quick question on rod bearings...
Old Mar 17, 2003 | 05:19 AM
Goldfingiz's Avatar
Default Quick question on rod bearings...
Hey guys does each cylinder require a different rod bearing? From what I understand, although there is no visible difference, each bearing is different and must go into a certain cylinder. Is this true?
Thanks,
Goldfingiz
Old Mar 17, 2003 | 05:27 AM
BabyDaddy's Avatar
Default Re: Quick question on rod bearings... (Goldfingiz)
Yes it's true.
When talking about oil clearances you need to start thinking about ten-thousanths of an inch (human hair = .002" so .0001" = 1/20th the size of a human hair).
There are slight differences in the big-end bore of the rod and the journal size of the crank.
You may end up with all the rod bearings being the same size (color code) but they still have to be measured and checked.
Old Mar 17, 2003 | 05:33 AM
Goldfingiz's Avatar
Default Re: Quick question on rod bearings... (BabyDaddy)
Thanks a lot for the reply. I never knew this until recently when my mechanic told me about it =\ Wasn't sure if he was correct.
1320london
Engine Machining & Assembly
May 25, 2017 10:04 PM
Phoenix5
Honda Civic (2001 - 2005)
Dec 23, 2013 11:07 AM
H22Luda720
Apr 5, 2006 05:27 PM
aznwash3wboi
Oct 3, 2005 09:57 PM
HybriDNA
Jan 1, 2003 11:15 AM
