quick fix for b pipe/heatshield rattle
Old Jan 10, 2003 | 05:23 AM
dip-set's Avatar
Default quick fix for b pipe/heatshield rattle
last night i encountered the imfamous rattle..im aiming more towards it being the heatshield for the cat...but theres the possibilty of it being the b pipe ive heard about...either way what would be a quick fix for either..heatshield i"ll probably just tighten up ,if possible but if its the b pipe..i have no clue...what are your suggestions, tips etc...thanks in advance to all with positive feedback...
a pic of the b pipe quick fix would do me good just in case its that or for future reference...
[Modified by teg-your-it, 9:41 AM 1/10/2003]
Old Jan 10, 2003 | 06:34 AM
Spade's Avatar
Default Re: quick fix for b pipe/heatshield rattle (teg-your-it)
I just removed them.
Old Jan 10, 2003 | 06:37 AM
YeuEmMaiMai's Avatar
i got a large metal strap around mine. the honda dealer did that when they replaced my timing belt and it was a no charge item
Old Jan 10, 2003 | 06:38 AM
dip-set's Avatar
Default Re: quick fix for b pipe/heatshield rattle (Spade)
can u explain how u did it cause i helped my brother take off his heat shield when it started to rattle and we went through hell to get it of...basicly ripped it off cause of the bolt that goes in under the cat..we couldnt reach it to unscrew it...so we hammered and chiseled it off...the b pipe i have no clues about..thankz
Old Jan 10, 2003 | 07:32 AM
Spade's Avatar
It's just a few 10 mm bolts that I got with a ratchet. Although I did have to cut the section that went around the O2 sensor for the cat heat shield.
But the other two just came off easily.
Old Jan 10, 2003 | 07:43 AM
dip-set's Avatar
the 10mm bolts are for taking off the heat shield correct...what about if its the b pipe rattling..do u have a fix for that...thankz alot for the positive feedback...
Capt Earl
Nov 6, 2008 04:06 AM
FURACERMAN
Welding / Fabrication
Jan 6, 2006 06:32 PM
LostCRX
Jun 5, 2005 10:40 PM
number7s
Feb 8, 2005 06:52 PM
