quick engine block stamp question
Old Nov 23, 2008 | 09:29 AM
tuquikgsr's Avatar
Default quick engine block stamp question
are there any b series engines that didint have a identification block stamp
i heard that obd-0 had no stamp is this true?
Old Nov 23, 2008 | 09:50 AM
gibsanez's Avatar
no.
Old Nov 23, 2008 | 06:49 PM
dcvt16's Avatar
i know that r-dot replacement blocks didnt have stamp. it does say r-dot on the block somewhere, the ones i've seen had it on the very bottom in the front of the block.
Old Nov 23, 2008 | 06:57 PM
HondachrisEJ1's Avatar
no every engine should have a stamp/casting number or call number r-dot or not r-dots may not be in the usual place. if there is no stamp you can bet it is probably stolen or was stolen!
Old Nov 24, 2008 | 11:13 AM
twentyhurtz's Avatar
every honda motor, even back into mid-early 80's had the stamp, sometimes its under a half inch of grease, but its there.
Old Nov 24, 2008 | 01:26 PM
CerealKiller's Avatar
x2
Old Nov 25, 2008 | 08:03 PM
dcvt16's Avatar
The r-dot block we had there was no stamp. In the place where the stamp should be it was in no way modified.( had the texured look like factory, and still had he raised part where flat part sat higher than the block) I will try to find a pic. Has anyone who is saying there is always a stamp bought a replacement block from the dealer.? I haven't, so im curious, because if this block we had was stolen and had the #'s removed this would have been the best job ever...
trying to locate pic
edit: I in no way condone or support the use of stolen parts. the block we had, we were told it was a replacment block from the dealer. it was almost brand new when we got it.
Old Nov 12, 2015 | 11:56 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: quick engine block stamp question
Bringing this back from the dead, it's the only piece of info I can find via google about odd honda block stamps.
The one in question is a supposed JDM 1.5L SOHC motor currently posted in the 92-00 section.
The block stamp has C V and a serial.
See for yourself and if you have any ideas, please bring them forward:
https://honda-tech.com/honda-civic-d.../#post50621918
And yes I know, a SEVEN YEAR OLD THREAD, I know. Like I said, this is the ONLY bit of info about legit oddball stamps. The only other finds were grind off stolen blocks.
The only thing I can find is there is a Honda Plant in Mexico the comes up in google with "C V", so I'm not sure if this is a direct replacement block produced in the Mexico plant so Stamped the Plant Location and a Serial number.... What do you all think?
Old Dec 13, 2020 | 11:31 AM
Shanehonda1216's Avatar
junior_tm
Mar 30, 2009 06:07 PM
velocityracer
Welding / Fabrication
Jun 8, 2005 11:55 AM
shadyCTR
Oct 8, 2003 09:48 AM
Rboosted717
May 8, 2003 08:33 AM
