Questions on take out the A/C System in my EM1
Old Jul 9, 2004 | 04:43 AM
Declectic's Avatar
Default Questions on take out the A/C System in my EM1
Well, what is there to do it? i got my own set of tools (finally), im just gonna take it out and bascially its gonna be trash
anyone have any how to's on it? Im sure i cant **** it up sense its already completely fucked. . . i just don't want **** anything else up
Old Jul 9, 2004 | 07:25 AM
JerseySiPOS's Avatar
Default Re: Questions on take out the A/C System in my EM1 (SeanJohn1802)
the first to do is drain the pressure from the valve. its located right by the ac fan.
Once you do that,
you can remove the hoses running to the compressor.
then you can take off the four bolts the hold the ac compressor. i kept my ac bracket on which is also held on by 4 bolts, so make sure your removing the 4 ac bolts.
take off the ac belt that is also around the crank pulley.
take out the ac fan which is on the right side of course when you look at the motor.
Then you can take out the lines that run all the way into the firewall and to the condensor.
you can either remove the lines from the condensor, cut them at the firewall, or unscrew them where the air filter is located. youll see the joints right around there for both lines.
You can remove the sensor or sensors that plug into the ac or fan. i forget whats there.
hope that helps.
Old Jul 9, 2004 | 09:59 AM
Declectic's Avatar
Default Re: Questions on take out the A/C System in my EM1 (JerseySiPOS)
yes that helps out a lot, thank you kindly
Old Jul 9, 2004 | 10:18 AM
i have a 2000 si. on top of that i remove my power steering and cruise control as well.....
and all sound deadening material, back seat bracket back seat, and tar paper and back seats belts and brackets.
thats a great weight reduction
Old Jul 9, 2004 | 11:59 AM
Declectic's Avatar
ahhah, yes it sure is, i plan to keep PS and such . . .i just want A/C gone for the full-race turbo kit
your **** sound GUTTEd
samson_420
May 20, 2021 03:29 AM
nickelz34
10
Aug 31, 2009 07:55 PM
IP RACING
Mar 13, 2009 09:16 AM
99fbpem1
Oct 13, 2007 05:52 PM
Truffle Shuffle
Feb 10, 2002 07:20 PM
