questions about 3,5 bar map sensor and TB
Old Sep 22, 2004 | 02:38 PM
hovic's Avatar
Default questions about 3,5 bar map sensor and TB
Hi guys..
Í´m planing to buy a AEM 3,5 bar map sensor. I often heard somthing about a pig tail but I don´t know what it is and what it is good for. Does it come with the AEM map sensors?
Next problem is.. I have to remove the stock map sensor. What happens with the map sensor mounting place at the Tb. I´ve seen a map sensor blocking plate on ebay but do I realy need it or are there other ways to block it? The AEM map will be conected to the golden eagle vacuum manifold. Some pics of your TB´s with a setup like mine would be fine..
Thanx for your help!
Old Sep 23, 2004 | 02:27 AM
hovic's Avatar
Default Re: questions about 3,5 bar map sensor and TB (hovic)
bump
Old Sep 25, 2004 | 05:44 AM
hovic's Avatar
bump
Old Sep 26, 2004 | 01:38 PM
hovic's Avatar
bump
Old Sep 26, 2004 | 03:04 PM
Garrett's Avatar
DO you ask AEM if they sell the pigtail with the map sensor?
From the Map hole in the TB just fill the hole
Old Sep 26, 2004 | 10:13 PM
hovic's Avatar
Default Re: questions about 3,5 bar map sensor and TB (Garrett)
no I didn´t aske them cause I don´t know what it is :-( Is it just the wiring to connect the map???
Old Sep 28, 2004 | 01:25 PM
tgreaves's Avatar
Yes.. The pigtail is the wiring connector to connect on to the map sensor.. Im not sure if yours comes with one but I know my AEM intake air temp sensor didnt come with one.. I still need to find one..
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
B_Swapped93
Feb 4, 2017 07:25 PM
TurboGS-R
Aug 18, 2005 01:28 PM
qwklude82
Jan 8, 2003 09:43 PM
