question on b16a2 vs b16b
Old Sep 25, 2003 | 08:40 PM
1hotvtec's Avatar
Default question on b16a2 vs b16b
I am doing a swap in my car this winter and am going to be buying either one of these motors. I was just wondering can I run forced induction on a b16b motor or will the compression of it stock and the induction just be to high. I want to put a vortech supercharger on these motor but have not decided what one to buy yet. I am getting one at the end of oct. I just don't want to blow the motor and have to pick another one up. I mean stock the b16a2 is 10.2/1 and the b16b is 10.8/1. Is there that much of a difference in just .6 compression. I don't know but I am sure that some one in this website does.
Old Sep 25, 2003 | 09:15 PM
Screaminsi's Avatar
Default Re: question on b16a2 vs b16b (SPOONCIVIC_97)
if i were you..just save your money for other essential stuff for the b16a if you are going to turbo it..b16b is not worth turboing especially if you want to up the boost..
-Conrad
Old Sep 25, 2003 | 09:32 PM
Diablo Tejano's Avatar
Default Re: question on b16a2 vs b16b (Screaminsi)
Must... resist... urge... to bash Vortech...
But if thats how you want to go...
I'd just get the b16a. The .6 bump in comp won't yield much if you're just going to run the FMU that comes with the Vortech kit. Also, the CTR cams are slightly more aggresive, and unless you dial out the overlap you'll just be blowing compressed air right through the CC.
Old Sep 25, 2003 | 09:47 PM
1hotvtec's Avatar
Default Re: question on b16a2 vs b16b (bluboy)
why do you want to bash vortech? would it be better to go with turbo vs supercharger?
Old Sep 25, 2003 | 11:05 PM
First of all lets not turn this into another Turbo vs JRSC vs Vortech thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONCIVIC_97 &raquo;</TD></TR><TR><TD CLASS="quote">why do you want to bash vortech? would it be better to go with turbo vs supercharger?</TD></TR></TABLE>
I don't like the fact that the Vortech will not reach maximum proscribed boost/whp until right before you shift. If you look at a dyno plot for a vortech you should notice that the area of the plot beneath the whp/wtq curves is significantly smaller than that of a turbo at the same max psi. I don't like that it is crank driven. I don't like an AWIC on a street car. I don't like changing a pulley to turn up the boost.
Don't get me wrong here, I think that the vortech is a viable option depending on your goals. It's just not what I would do.
What do you want to do with your car? Drag? Auto-x? mAd 70p 5p33d hWy 5tuN7iN?
What is better for you wil depend on your goals.
jM
Old Sep 26, 2003 | 11:15 AM
1hotvtec's Avatar
well I just thought that because honda lack torque that the supercharger would help in the bottom end and vtec would take care of the top end. Then if I needed nos I could get that for topend as well. I would like something street quick. You know light to light. But I also want to be quick on the high way. I am just loking to get the best of both worlds. I would like top end but really I would just like to pull up to somebody and take them off the line. Am I making any sense at all?
Old Sep 26, 2003 | 11:45 AM
pro1342's Avatar
B16A has a shorter deck height, the B16B is taller---the same as gsr/ls/crv/itr.
Old Sep 26, 2003 | 11:54 PM
B16, rods, &gt;9.5:1, Hondata, T3/T4 .63a/r etc.
Old Sep 29, 2003 | 01:41 AM
Mugen_Power's Avatar
Default Re: question on b16a2 vs b16b (Masekja)
is there any difference performance wise?
Old Sep 29, 2003 | 03:48 AM
VTECorona's Avatar
Default Re: question on b16a2 vs b16b (Mugen_Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen_Power &raquo;</TD></TR><TR><TD CLASS="quote">is there any difference performance wise?</TD></TR></TABLE>
B16B is 185 hp and 117 ft-lbs out of the box I think, if that's what you're referring to
Old Sep 29, 2003 | 04:24 AM
jerseybrandon's Avatar
With boost, go B16A. Turbo versus supercharger is an entire other issue.
Old Sep 29, 2003 | 05:35 AM
TimoneX's Avatar
New User
Default Re: (jerseybrandon)
B16 with JRSC or turbo.
Forget the Vortech was ever made. You'll not miss much.
Old Sep 29, 2003 | 07:36 AM
976's Avatar
976
New User
Default Re: (TimoneX)
I disagree, go B18B with turbo, add sleve block guards and you can make it into the 11's with a light ride...
Old Sep 29, 2003 | 08:26 AM
VTECorona's Avatar
Default Re: (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">I disagree, go B18B with turbo, add sleve block guards and you can make it into the 11's with a light ride...
Yes, you shouldn't even waste the money for a vtec motor if you're going turbo. B18B's can be had for cheap.
Old Sep 29, 2003 | 10:06 AM
976's Avatar
976
New User
Default Re: (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, you shouldn't even waste the money for a vtec motor if you're going turbo. B18B's can be had for cheap.</TD></TR></TABLE>
ekhatchswap
Jan 7, 2007 06:36 PM
MassCivicMan987
Sep 6, 2005 10:01 AM
MrPink96
Jun 26, 2005 08:15 AM
Terrible One
Feb 7, 2005 12:29 PM
Austinbionic316
Jul 5, 2004 10:48 AM
