question about how much to torque to apply to the rod bolts !!!!
how much to torque to apply to the rod bolts !!!! I ask my teacher and he said there is a special amount of torque that u apply with a torquimeter to the bolts that hold the rod with the crank ?? any clue
sorry for my bad english
I hope you torque your mains let alone everything else to proper specs...
If they are ARP rod bolts on the rods you pictured there should of been a instrustion sheet come...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_beat »</TD></TR><TR><TD CLASS="quote"> I ask my teacher and he said there is a special amount of torque that u apply with a torquimeter to the bolts that hold the rod with the crank ??</TD></TR></TABLE>
normally you use a torque wrench.
23 ft/lbs ? I could swear it's 28 ft/lbs for gsr eagles.
I recommend you contact arp directly tho... they will give you the info no problem. Torque specs are something you need to be definite about.
