Question about b16 transmission spline/bolt battern differences
Old Nov 21, 2003 | 03:26 PM
EgSalad's Avatar
Default Question about b16 transmission spline/bolt battern differences
Ive got a USDM 99 Si transmission, and im in quick need need of a new clutch. So, a buddy of mine has a new stock clutch disc and plate for a 94 del sol Y21... he said hed give it to me for next to nothing.
Are the transmission spline sizes and flywheel bolt patterns different between the two trannys???
Old Nov 22, 2003 | 07:32 AM
EgSalad's Avatar
Default Re: Question about b16 transmission spline/bolt battern differences (jdmbran)
Nobody???
Old Nov 22, 2003 | 08:18 AM
mmuller's Avatar
Mad Scientist
it would work fine, the smaller spline was up to 91
Old Nov 29, 2003 | 12:01 PM
EgSalad's Avatar
Default Re: Question about b16 transmission spline/bolt battern differences (mmuller)
Are there any differences in the 99 Si and 94-6 del sol b16 flywheel bolt patterns? (how the clutch bolts up to the flywheel?)
Old Nov 29, 2003 | 12:06 PM
pills_PMD's Avatar
as far as i remember they are exactly the same... i interchanged a 00 ITR clutch with a 94 del sol VTEC flywheel, and from what i remember the 99-00 Si are interchangable with ITR parts.. and the 99-00 si are interchangeable w/ del sol VTEC parts... soooooo it should work fine for you
rolow
Transmission & Drivetrain
Oct 6, 2016 05:48 PM
civictech22
Aug 17, 2004 03:49 PM
swlabhot
Jan 27, 2003 11:10 AM
my2ndtool
May 24, 2002 10:35 AM
