Question about Apexi timer....
Old Mar 12, 2003 | 06:44 PM
98DC2's Avatar
Default Question about Apexi timer....
i have a N/A 98 gsr mildly moded. i do have a fpr, bigger fuel rail, & guage attached to fuel filter. i plan to keep it all motor. basically, i want to know my a/f ratio w/ out getting a guage that doesn't really give a true reading because it's always fluctuating. i want to know if this would be a good investment. and how does the O2 function work? thanks...
Old Mar 12, 2003 | 07:01 PM
98DC2's Avatar
Default Re: Question about Apexi timer.... (98DC2)
ttt
Old Mar 12, 2003 | 07:45 PM
sslude's Avatar
are you talking about a VAFC? i would highly recomend it and a dyno tune. that would help out a lot. on lude they give about 9WHP peak and about 25WHP mid-range
Old Mar 13, 2003 | 06:01 AM
98DC2's Avatar
Default Re: Question about Apexi timer.... (sslude)
no, i'm talking about the Apexi N/A or Turbo timmer. it has 4 functions: A/F, O2, batterey, & engine timer. it's pretty small, unlike a VAFC.
Old Mar 13, 2003 | 06:44 AM
IN VTEC's Avatar
The gauge is only as good as the oxygen sensor.
Old Mar 13, 2003 | 07:56 AM
98DC2's Avatar
Default Re: Question about Apexi timer.... (IN VTEC)
so basically if my o2 goes bad, the timer will let me know?
Old Mar 13, 2003 | 08:09 AM
IN VTEC's Avatar
It'll tell you the oxygen sensor voltage and approximate AFR, but those numbers are only valid when the oxygen sensor is at nominal operating temp and WOT. Even then, the numbers won't be accurate.
The only thing it'll be useful for is telling you whether the engine is leaning out at WOT.
rafael_dias
10
Mar 27, 2005 01:07 AM
Pullig
Feb 11, 2005 08:38 PM
LSVTEC 91 Civic
Apr 18, 2004 06:03 PM
