Q?: What's needed to add rear swaybar to EG?
I am planning on adding a rear swaybar to my '94 SI Coupe (ex in the states). I know I require new LCA's to have the mounting points. I was going to a junkyard and pick up a set of GSR LCA's.
Whar are all the parts I would require to add a swaybar? Also, what size of swaybar can I use if I do not feel like adding subframe support?
EDIT: By the way, I plan to run the stock suspension, so any suggestion as to sway bar size that will not tear the subframe would be appreciated. I am not looking for anything agressive, just something to help with body roll.
Modified by Deam at 9:58 AM 8/3/2004
Re: Q?: What's needed to add rear swaybar to EG? (Deam)
you could just buy a bar that is designed for a 92-95 hatch. For example, the progress rear bar comes with everything that you need to mount it to a swaybar-less car.
Re: Q?: What's needed to add rear swaybar to EG? (shaundrake)
the 92-95 did not have a rear sway bar.
My major question is, should I be concerned about subframe tearing using the GSR swaybar on stock suspension withotu reinforcement?
EK99hatch
09-15-2006 07:32 AM
