Q about distributor...
Old Oct 15, 2007 | 10:44 AM
allmotaR's Avatar
Default Q about distributor...
Story in short; going 130mph, car dies & all lights come on without thinking I try'd restarting it by key with no luck, I then attempted a breif compression start again no luck so I pull over, open the hood to find the #1 spark plug wire came off the distributor, I then test for spark and get none, I then towed her home and bought a new dist. it was an obd2 dist. which I converted to obd1, tossed it on and she fired right up. It runs, idles, and drives fine, however the car does feel a little slugish compared to before, Ive adjusted the dist + & - with no differ in performance, mainly the vtec and anthing above 5krpm isnt as loud and as strong as it was previously & it deffinately sounds muffled like its running in safe mode .. thanks in advance for any and all help.
Old Oct 15, 2007 | 08:59 PM
egsleepercivic's Avatar
did you jump the service connector when you set the timing?
Old Oct 16, 2007 | 10:09 AM
allmotaR's Avatar
Default Re: (egsleepercivic)
no sir. . .
Old Oct 16, 2007 | 12:13 PM
jump the service connector then set your timing, that should help
Old Oct 16, 2007 | 12:58 PM
B16B_coupe's Avatar
HRD PKR
check your spark plugs to while ur at it.. you put new wires on this time around also/??
Old Oct 17, 2007 | 10:13 AM
allmotaR's Avatar
Default Re: (B16B_coupe)
jumped it, timed it, got it to 13degrees at tdc.... runs good, vtec just isnt hittin as hard, but the mph is there... also disabled the batt. throwing 45 rich or lean... checked plugs too... they look good, and are only 5-6k miles old... ngkr, 11's.
Old Oct 17, 2007 | 12:27 PM
which engine do you have, stock timing on B16a is 16* +/- 2*
Old Oct 17, 2007 | 05:20 PM
allmotaR's Avatar
b18c1&5 are 16 +/-2degrees as well according to the haynes. stock gsr.
Old Oct 17, 2007 | 05:26 PM
so if your timing is @ 13* and you are feeling slugish this might have something to do with it, set to 18* and run 91 or higher octane
gl
Old Oct 17, 2007 | 05:58 PM
PyroProblem's Avatar
advance your ignition timing to 16-18 deg. and you will definately regain some pep!
Old Oct 18, 2007 | 11:23 AM
allmotaR's Avatar
Default Re: (PyroProblem)
Alright. I got the timing at BTDC?, mark in between. I previously had it set at TDC, the single white mark, and the gun read 13degrees. Well I started all over, and the gun read 0 degrees and I adjusted the dist until i got it to BTDC again the mark in the middle, however the dist is almost all the way advanced... dont know what next to do...
Old Oct 18, 2007 | 02:58 PM
Default Re: (allmotaR)
Perhaps your intake cam somehow got a tooth off?
Sometimes they will still run with the tooth off, but just feel weak and sound funny.
This might be why you can get the proper ignition timing?
Or maybe the timing light is off? Try a second one to double check. Ive heard they are sensitive.
Tommy818
28
Oct 22, 2012 10:00 AM
Sturg
Oct 27, 2009 12:04 AM
300gtzr
Dec 16, 2008 04:02 PM
unLuckylude666
Apr 17, 2004 09:41 AM
