pvc valve with oil catch can..
Old Sep 22, 2002 | 01:44 PM
ILOVEGIRLS's Avatar
Default pvc valve with oil catch can..
do u still use the pvc valve with the oil catch can? i search and read but there nothing that says anything about this.
Old Sep 23, 2002 | 03:56 PM
ILOVEGIRLS's Avatar
Default Re: pvc valve with oil catch can.. (ILOVEGIRLS)
Old Sep 23, 2002 | 08:37 PM
MikeSarr_GSR's Avatar
yea man it goes in the top of the can, thats how it works
Old Sep 24, 2002 | 09:08 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: pvc valve with oil catch can.. (MikeSarr_GSR)
Any pics or installation guides for these oil catch cans? I am currently lookin into getting one, either an SSR, Greddy, or the Cusco can....
Old Sep 24, 2002 | 09:17 PM
Accord94DX's Avatar
Default Re: pvc valve with oil catch can.. (Blue-Civic-Hybrid)
i have a USDM moroso one. Mine is old school though...
Old Sep 25, 2002 | 05:06 AM
BSQ's Avatar
BSQ
You can go to my website at http://www.geocities.com/bretq/DIY_O...tructions.html for information on assembling and installing an oil catch can. I used the Moroso because it contains baffling, which helps to seperate the oil droplets from the blow-by gases. Here is a diagram which shows how the baffling works.
Old Sep 25, 2002 | 06:48 AM
earl's Avatar
Default Re: pvc valve with oil catch can.. (BSQ)
I miss TOO. This system works well (not perfect) and keeps you smog legal.
Old Sep 25, 2002 | 07:04 AM
BSQ's Avatar
BSQ
Default Re: pvc valve with oil catch can.. (earl)
I learned a lot from T.O.O.
I'm extremely pleased with my DIY oil catch can. I catch ~1/8 - 1/4 cup of oil every 3,000 miles and this is on a NA stock motor.
Old Sep 25, 2002 | 07:27 AM
jdmcx's Avatar
hey i have an ls vtec and it has the stock catch tank on the back of the block
i jus purchaced a cusco catch tank and i thought that you put it between the tube that comes from the crank case to the intak pipe am i wrong
from your pic i think you have to disconect the hose on top of the catch tank (stock ) and run the one that comes out of the stock tank to one end of the cosco one and then connect the return line to the tube that was connected to the top of the stock tank
sorry i am confused don't mean to bother you
jason
[Modified by jdmcx, 10:41 AM 9/25/2002]
Old Sep 25, 2002 | 02:20 PM
ILOVEGIRLS's Avatar
Default Re: pvc valve with oil catch can.. (jdmcx)
more thoughts..ive heard so many differents ways..sheesh
Old Sep 25, 2002 | 02:34 PM
BSQ's Avatar
BSQ
Hopefully this diagram from the Helms manual will clear things up.
Larger image (cut and paste link): http://www.imagestation.com/picture/...d.gif.orig.gif
Old Sep 26, 2002 | 07:19 AM
jdmcx's Avatar
hey do i take the original pcv valve off when i put the new on on the catch tank (ford truck )
thanks
Old Sep 26, 2002 | 03:57 PM
Kool-Lude's Avatar
thanks
Yes, the stock pcv valve is removed and replaced with the one on top of the catch can. Use an elbow or some other connection that fits into the stock pcv valve gromet and attach a line from there to the can.
Tip: use trans-cooler line instead of the clear Home Depot tubing or fuel line. The trans-cooler line is reinforced and will hold up better over time.
I have a question for you though...if your block has a factory catch can already, why add another?
Old Sep 26, 2002 | 04:03 PM
Kool-Lude's Avatar
So 2 ounces of oil/gunk caught in the can after 3k miles is good for NA stock?... I was expecting more when I emptied mine for the first time last week, but only got 2 oz. I consume 1.5qts every 3k miles...and now know that its not all going through the pcv system.
[Modified by Kool-Lude, 1:05 AM 9/27/2002]
Old Sep 26, 2002 | 06:55 PM
ILOVEGIRLS's Avatar
Default Re: pvc valve with oil catch can.. (Kool-Lude)
trans cooler line..where do u get those?
Old Sep 26, 2002 | 06:57 PM
ILOVEGIRLS's Avatar
so u dont use the pcv valve like the diagram above?
[Modified by ILOVEGIRLS, 7:57 PM 9/26/2002]
Old Sep 26, 2002 | 09:26 PM
Kool-Lude's Avatar
The diagram is correct...read my response again. The concept is simple. You are putting a catch can inbetween the pcv system and simply relocating the pcv valve from its factory location to the top of the can. Make sense?
You can buy trans-cooler line at Autozone or Pepboys.
[Modified by Kool-Lude, 6:32 AM 9/27/2002]
Old Sep 26, 2002 | 11:04 PM
Loved
Great thread, keep the info coming..and what ever happend to T.O.O.? His board seems to be shut down...
Old Sep 27, 2002 | 07:28 AM
jdmcx's Avatar
so i take the stock one of and buy the new one (Ford trunk one ) and just follow the diagram
Old Sep 29, 2002 | 01:24 PM
ILOVEGIRLS's Avatar
thats what im reading so far.. but will the vaccum be strong enough by the time it reaches the catch can. so far this is what i see...
from the black canister on the back of the block..to the "relocated pvc" on the catch can..then back into the intake.
Ohannon7
Aug 17, 2008 11:27 PM
Chris F
22
May 31, 2005 03:50 PM
gooknom
Mar 17, 2004 10:20 AM
mixxed
Jun 27, 2003 07:52 AM
b16awarrior
Sep 21, 2001 09:27 AM
