putting wrist pins on pistons
Old Jan 11, 2006 | 07:21 PM
jakscivic's Avatar
Default putting wrist pins on pistons
Ok, my manuals dont say anything about how to do this. Is there an easy way to do it. Its pr4 rods with p30 pistons. It looks like you have to use a vise to get it in. Is there a lube i have to use or anything?
Old Jan 11, 2006 | 07:39 PM
Tad's Avatar
Tad
i think u need to have a machineshop do it?
Old Jan 11, 2006 | 08:24 PM
jakscivic's Avatar
any other opinions, im sure someone has done this before
Old Jan 11, 2006 | 08:33 PM
deucedeuceEK's Avatar
Default Re: (jakscivic)
Machine shop
Old Jan 11, 2006 | 08:46 PM
jakscivic's Avatar
ok cool thanks guys
Old Jan 11, 2006 | 09:54 PM
runeminaEF9's Avatar
yes, they have to be pressed in at a machine shop. if you go puttin em in the ol' lockjaws of death, you'll just do damage.
Old Jan 15, 2006 | 07:13 PM
jakscivic's Avatar
ok. What if the wrist pin wasnt exactly centered on the rod?
Old Jan 15, 2006 | 08:03 PM
No ifs, ands, or buts. If somethings not perfect don't use it.
Old Jan 15, 2006 | 10:13 PM
jakscivic's Avatar
yeah, thats nice. But i was wondering what would happen if one wasnt exactly center
Old Jan 16, 2006 | 12:12 AM
jakscivic's Avatar
mmmmmmmmmmmmmmmmmmm
Old Jan 16, 2006 | 03:41 AM
shorto85's Avatar
Kaboom... really though I dont know... if one wasn't exactly center then a person most likely wouldnt go putting it back in their motor.
Old Jan 16, 2006 | 06:03 PM
jakscivic's Avatar
well im sure some one knows what would happen. Wear on bearings?? does no one have an idea?
Old Jan 16, 2006 | 06:23 PM
v4lu3s's Avatar
RTFM
i would like to know how the wrist pin could NOT be cetnered on teh rod?
Old Jan 16, 2006 | 09:23 PM
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">i would like to know how the wrist pin could NOT be cetnered on teh rod?</TD></TR></TABLE>
Werd!
Old Jan 16, 2006 | 10:33 PM
jakscivic's Avatar
well since the wrist pin is put through the hole on the rod there is plenty of room for error. so if the wrist pin was off by just a little what would happen?
Old Jan 17, 2006 | 03:58 AM
v4lu3s's Avatar
RTFM
if you dont put the wrist pin through the rod centered it doesnt go through. unless you found a trick to make metal pass through metal......
Old Jan 17, 2006 | 04:48 PM
jakscivic's Avatar
i dont think you are getting what im talking about. once the wrist pin is through it looks like a T. ok. so say that the top part of the T is just a little to the right/left. What would that do? wear the bearings? or what?
Old Jul 14, 2007 | 01:18 PM
ToeJam's Avatar
back from the dead because i want to know what happens when the pins are not centered.
Old Jul 14, 2007 | 04:00 PM
gsrious's Avatar
Default Re: (ToeJam)
if by "centered" you guys mean that it isn't spaced out evenly when pressed in... kind of like...
..........ii......................ii
^^sorry for the crappy use of keys(i didn't want to waste time drawing it out). the [=======] represents the wrist pin. the [ii and downward] represents the rod.
to answer the mentioned question, it should be fine as long as the wrist pin is making contact to both ends of the piston(hope that makes some since to you guys)
Old Jul 14, 2007 | 09:53 PM
ToeJam's Avatar
Default Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">if by "centered" you guys mean that it isn't spaced out evenly when pressed in... kind of like...
to answer the mentioned question, it should be fine as long as the wrist pin is making contact to both ends of the piston(hope that makes some since to you guys)</TD></TR></TABLE>
sorry but that doesnt look like anything that goes to a car. haha
When the piston, rod, and wrist pin are not perfectly centered, meaning you can push the piston to one side and the pin is almost flush with the piston and if you push it the other way and its about 2mm to being flush.
We are talking about oem type pistons btw. You have to push these on.
Old Jul 17, 2007 | 12:31 AM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToeJam &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>lack of imagination owns you.
just a message to the thread starter. pm me if you need any info. i can help you there.
terrorhawk
11
Jan 18, 2012 02:28 AM
rich7777
Feb 23, 2010 03:50 PM
94-integra-ls
Feb 5, 2006 01:09 PM
97CTR
Oct 17, 2005 05:55 AM
infamousALLMTR
Sep 20, 2002 08:28 AM
