What is this hole in the block for??
Old Jun 24, 2006 | 02:41 PM
slowteg550's Avatar
Default What is this hole in the block for??
b18a block, no pics right now...but if you are looking at the back of the block, this hole is located about 1 inch to the right, and 1/2 inch above the left port that you remove for a catch can. The hole is threaded and large enough for your pinky to fit in... oil temp sensor?
Old Jun 24, 2006 | 04:25 PM
tha_badguy's Avatar
knock sensor...
Old Jun 24, 2006 | 09:08 PM
slowteg550's Avatar
Default Re: (tha_badguy)
It looks as if it goes all the way into the block, like you can see the backside of the sleeve...
Old Jun 25, 2006 | 07:44 AM
slowteg550's Avatar
Default Re: What is this hole in the block for?? (slowteg550)
Old Jun 25, 2006 | 02:45 PM
tha_badguy's Avatar
if its right under where the head bolts up
& its a pre-threded hole that does not lead into the block then its 4 a knock sensor
if its to the left of the oil filter & it leads into the block its where u oil pressure sensor goes
Old Jun 26, 2006 | 08:25 AM
lightcrx's Avatar
there used to be a little nipple there that connected to the black breather box on the back of the block.
-joseph
Old Jun 26, 2006 | 12:23 PM
hybrid1990crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">knock sensor...
he said b18a, no knock sensor.
Yes its for the breather box, like the dude above me said.
Old Jun 26, 2006 | 03:27 PM
lightcrx's Avatar
Default Re: (hybrid1990crx)
yea like i said
Old Jun 26, 2006 | 07:42 PM
slowteg550's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">
Yes its for the breather box, like the dude above me said.</TD></TR></TABLE>
the breather box hole is to the right of the oil filter, already plugged it... this one is to the left of the oil filter, threaded... and large enough to stick your pinky in. Oil pressure sensor?
Old Jun 26, 2006 | 08:03 PM
Default Re: (slowteg550)
oh duh me.
yeah i replace one of those yesterday. sounds like oil pressure.
Old Jun 26, 2006 | 08:06 PM
slowteg550's Avatar
any idea where I can get a plug for it?
Old Jun 27, 2006 | 06:57 AM
you could just take the sensor off a d series block and put it in. or a b series.
or im sure you could go to a hardware store and find something that will thread into it to block it off.
Old Jun 27, 2006 | 09:39 AM
lightcrx's Avatar
so are you talking aout the breather nipple or the oil pressure sender hole....
-joseph
Old Jun 27, 2006 | 03:59 PM
slowteg550's Avatar
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">so are you talking aout the breather nipple or the oil pressure sender hole....
-joseph</TD></TR></TABLE>
I have the breather fittings from honda, we are talking about the hole between the left breather fitting, and the oil filter...
Old Jun 27, 2006 | 04:35 PM
slow poke's Avatar
Yea dude, thats for oil. You can plug it with a 1/8 BSPT (NOT NPT FROM LOWES) plug. Or, just get the switch off any old Honda motor and screw it in there. Dont over tq it.
bb6guy
Oct 25, 2010 04:27 PM
Japankid
Welding / Fabrication
Apr 9, 2009 12:35 PM
krysted9354
Dec 28, 2008 12:43 PM
SkertySkerty
Jul 4, 2007 04:21 PM
