Putting Carbs on a D16Y8
I was wondering how I could install carbs on my D16Y8. I don't know if it's possible or if vtec will work if I do. I also don't know what I would do about the rest of the ECU system other then the fuel part. I know it sounds crazy. If anyone knows anything about this let me know.
hi everyone, i know this is an old thread but im wondering the same thing.
I would love to run a set of twin weber dcoe40's on my civic but im a bit lost how to go about all the ignition side of things
could anyone help please
i think you would get more bang for your buck if you went individual throttlebodies.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/d-series-carburator-manifolds-1979774/
I have never seen anyone use a traditional carb on a honda engine (i'm sure someone has, though). An ITB is usually not streetable, because it's suited for WOT. It eliminates the intake manifold, throttle body and air cleaner assembly. Pretty much the closest you can get to having no intake manifold, cylinders will get a lot of air at high RPM. Low RPM will suffer. Each cylinder will have its own little trumpet as a runner with a fuel injector. It will require EMS, and it's expensive unless you jerry rig it yourself. You'd probably have better luck using a carb, but I don't see any benefit in that, either. Fuel injection will be more precise, and it's highly tunable. I don't see a honda engine running good with a carb.
here is a write up used with a z6 but it should be similar
http://www.4guk.co.uk/viewtopic.php?f=22&t=17211
u might have to register to see it though
MIBPreacher
Nov 6, 2012 08:27 AM
