Push start
Old Sep 22, 2016 | 11:34 PM
rodz's Avatar
Default Push start
Can someone help me wire a push start using a relay I have a button that I want to use but I don't know how to wire it can someone please help
Old Sep 23, 2016 | 10:33 AM
fcm's Avatar
fcm
Old Fart
Default Re: Push start
MM&Y of car would help, auto or 5 speed?
Most, if not all Honda/Acura use a black/white wire as the starter lead, at ign. switch. 94.
Old Sep 23, 2016 | 10:44 AM
rodz's Avatar
It's a 96 honda civic 5spd
Old Sep 23, 2016 | 11:00 AM
fcm's Avatar
fcm
Old Fart
Then black/white, disconnect from ign. switch, [can be de-pinned] connect that to #30 of a relay supply 12V+, [from 12V constant free pin on under dash fuse box] to #s 85 and 87 of the relay wire one side of switch to ground and the output of switch to #86 of the relay, your done.
Turn ign. on and press clutch and press start button. 94
Old Sep 23, 2016 | 12:04 PM
rodz's Avatar
Thank you so much I'm gonna try it
Old Sep 23, 2016 | 12:18 PM
rodz's Avatar
can you help with this what does he mean by a negative trigger
Old Sep 24, 2016 | 08:00 AM
fcm's Avatar
fcm
Old Fart
The relay is energized, [turned on] with a ground, "negative trigger"
A relay can be controlled/energized/turned on using a ground or 12V+, Terminals #85 and #86 at the relays coil, [switch] and are non polarized, meaning you can connect a neg. or a pos. to either terminal and as long as the opposite terminal gets the opposite polarity it will work, so if to ground #85 and supply 12V+ to terminal #86 the relay will energize and the revers is also true, supply 12V+ to one of the terminals and ground the other terminal and the relay will energize. 94
Old Sep 24, 2016 | 11:13 AM
rodz's Avatar
Wow thank I understand it now I just didn't wanna burn my switch that's all thank you for your help and time
Old Sep 24, 2016 | 04:12 PM
fcm's Avatar
fcm
Old Fart
You do not need much of a switch because all it is doing is turning on the relay, about 250mV to energize and 125mV to keep it on, your push button switch is most likely a 5A switch, more then 10 times the amperage needed. 94
NOSblast
Nov 12, 2012 10:17 AM
spcrxracer
Audio / Security / Video
Oct 16, 2011 08:54 PM
gunmetalteg1
45
Sep 30, 2009 07:20 PM
Joon Joon
27
Oct 23, 2005 05:49 PM
integra99blue
Aug 16, 2001 09:49 PM
