pulling ef out of storage
Old Sep 29, 2013 | 01:50 PM
logicdc's Avatar
Default pulling ef out of storage
Hello,
I had a bad knee injury so I had to give up driving my ef for the last few years. I was not able to do anything to it before storing it, other priorities. Anyway, I am nostalgic and think I can start driving it again.
But with ethanol infused fuel here in AZ I have heard it is tough on tanks and fuel lines. How should I go about getting it back to running shape.
Ls/vtec with b16a pistons - b16a head - gsr cams - y1 tranny - chipped p28.
flush gas tank?
replace gas tank from one in yard? new autozone tank?
change out fuel pump?
flush radiator
change oil
pull plugs and put in a little Marvel Mystery oil
turn engine over by hand
What are the chances the oxygenated fuel ate the fuel lines?
TIA
Old Sep 29, 2013 | 01:57 PM
jdmh22eg2's Avatar
Default Re: pulling ef out of storage
i would deff do all you listed as far as prep to start.
as for fuel issue, i had to deal with near same a yr ago. i bough a shell that had 1/4 tank of e10 and sat for over a yr. i tried pressure washing tank 3 times. i ended up killing 2 pumps and filling up 5 pump sock filters. i the end i put new 255 and junk yard (clean) tank in it no problems since. so i HIGHLY recommend a new/used tank. as for the lines they were fine.
one thing when doing marvel oil and hand turning. rock crank SLOWLY in each direction a SMALL bit before just going at it. i feel it is better on breaking rings loose without hurting them
Old Sep 30, 2013 | 09:11 AM
logicdc's Avatar
Ok new fuel sock and new tank ordered.
Should I replace the fuel filter now or later?
Timing belt and water pump before starting or after?
Clean injectors and fuel rail before starting or after?
Old Sep 30, 2013 | 09:35 AM
jdmh22eg2's Avatar
filter now
belt if up to it (idk any issues u may have) i would -- due to hot and cold changes/dry rot
water pump i do if you do change belt
inj not sure maybe have a spare set on hand.
rail prob ok
ed62ef9
Oct 17, 2013 06:29 PM
BIGef
Sep 10, 2013 03:02 AM
KarmaJosh
Feb 23, 2010 07:47 AM
lilbill_ed8
Dec 19, 2008 08:18 PM
salman
Nov 20, 2006 07:22 PM
