Random hose in type r swap? What is it?
Old 06-09-2013, 02:09 PM
Rawrlos's Avatar
Default Random hose in type r swap? What is it?
Hey guys my friends civic type r has a hose with a weird metal piece as a plug in the end of it, I'm wondering what it is or where it's suppose to go to, I think it's t'd off to the oil. Let me know what you guys know please! Thanks! car is also running kind of slow, vtec works fine tho, new spark plugs and recent oil change. Running on type r Ecu as well. Any ideas of why too?
Old 06-09-2013, 02:10 PM
Fliptard's Avatar
Default Re: Random hose in type r swap? What is it?
it's for power steering
Old 06-09-2013, 02:12 PM
RESIDENT
TypeRfit's Avatar
x2
Old 06-09-2013, 02:14 PM
Rawrlos's Avatar
Thank you guys! Any ideas of why its running slow? Another friends b18b1 integra pulls away from this car all the time in 3rd
Old 06-09-2013, 02:16 PM
RESIDENT
TypeRfit's Avatar
Compression check is the first thing I would do.
Old 06-09-2013, 02:38 PM
Rawrlos's Avatar
I did notice a small leak on his head gasket I think, we will switch that out soon then see if it fixes it if not then compression test.. Just cuz idk how much a compression test goes for $$$
Old 06-09-2013, 03:00 PM
BrayanT's Avatar
What would be a good head gasket brand for B18C type-r?
I look at golden eagle and inline pro any suggestions?
Old 06-09-2013, 03:09 PM
RESIDENT
TypeRfit's Avatar
OEM
Old 06-09-2013, 06:47 PM
Runnerdown's Avatar
If its leaking oil from the coner of the block its probably not the headgasket. Look at all the oil seals on the side of the head vtec solenoid etc, they usually cause that. It should not be getting passed by an LS, i'd take a closer look at the swap wiring, it look sloppy.
Old 06-09-2013, 09:27 PM
Rawrlos's Avatar
It is leaking oil from the corner of the book... Il check the oil seals and also the wiring, yeah it was done a bit sloppy :/ but that's what I'm saying! Something had to be up il check the wiring like I said but honestly what am I looking for in specific? Loose cables and connections? -___- sorry
Old 06-09-2013, 09:38 PM
raverx3m's Avatar
lets see
wiring hacked problem
unturned wrong ecu
no vtec because of some other problems
lack of maintenance
spark plugs cap and rotor
clogged exhaust
bad o2 sensor
clogged fuel filter clogged injectors
incorrect timing
and many more
Nicolai
06-16-2013 03:38 PM
carlosp38
03-30-2008 06:31 PM
SOHCROB
02-02-2003 11:33 AM
Chubz
04-25-2002 03:24 PM
turbo_ef9
04-13-2002 01:02 PM
Quick Reply: Random hose in type r swap? What is it?
