Problems with civic
i got a bulit ls/vtec with je pistons,pr3 head P&P,crower cams stage2 drag, crower valve springs with retainers,skunk2 intake manifold,aem cam gears,b16 oil pump,dc 4-1 header,p28 ecu with mugen program
fuel psi @50psi cam gear intake+2.5 ex+3
Denso spark plugs .44 gap
timing set at stock
the Problem is the start cutting power at 8500rpms it just started i was going to 9400rpms with no Problems but now i took the motor out and put new SS valves in and a new block its like it is missfireing or somthing or how the valves are adjusted what can make it do this
timing set at stock
NiiS
41
Apr 7, 2003 07:36 PM
