Problem with ctr lsd
Old Aug 14, 2003 | 05:49 PM
Spids5's Avatar
Don't judge or question
Default Problem with ctr lsd
After installing my ctr lsd and jdm itr fd my 2000 civic si it hasn't been driving right. When I accelerate(mainly when its full throttle) I can feel my tires vibrating. It kinda feels like the lsd chatters. I also installed a camber kit and I need an alignment but thats not the problem because when I'm on the freeway it drives smooth. I hope I did the installation right because no one could give me a straight answer on what I needed. Everything fit right and felt right until I drove it. Do I need a addative for the lsd to get ride of the chatter or do I have to break it in some way? Any info would help. Thanks.
Old Aug 14, 2003 | 11:28 PM
Spids5's Avatar
Default Re: Problem with ctr lsd (spids5)
Bump for the late nighters.
Old Aug 15, 2003 | 04:37 AM
mattb16a1civic's Avatar
can u describe the problem a little more indepth
Old Aug 15, 2003 | 11:44 AM
PupaScoopa's Avatar
Default Re: (mattb16a1civic)
It could very well be your camber/alignment changes. Under load, the alignment can change a little bit (forces from the drive wheels). Get the alignment first or DIY and then try the test again.
Old Aug 21, 2003 | 05:31 PM
Spids5's Avatar
Default Re: (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">It could very well be your camber/alignment changes. Under load, the alignment can change a little bit (forces from the drive wheels). Get the alignment first or DIY and then try the test again.</TD></TR></TABLE>
I got an alignment today and it still vibrats when I accelerate so I'm thinking it has to be the lsd. I think the problem is with the shims. When my dad and I put the tranny back together we forgot to check the clearances. He thought that they were fine because the lsd spun freely when it was sitting in the case. Maybe the lsd is moving because there is to much room. I forgot to mention that I had to replace the passanger side axle with a gsr axle. The part numbers were the same for the si and the gsr so it should be fine. Has anyone had problems with a gsr axle in a si. I going to check the clearance when I have time but before I do I want to know if anyone has had the same problem.
Old Aug 21, 2003 | 06:09 PM
Highrevs99's Avatar
Default Re: (spids5)
I doubt its the shims on a Si trans . You should use a LSD type oil from acura but still that wont make it shutter . The symptom you descirbe is more likely a bad axle , I have had several go bad and do just that vibrate under excelleration . If this unit was used it could be worn out and need of reshimming but I would check my axles first . Oh and I beleive clearance is .1mm on bearings .
Old Aug 21, 2003 | 08:10 PM
PHiZ's Avatar
Default Re: (Highrevs99)
I found this, just passing it along, not an endorsement.
-PHiZ
Old Aug 22, 2003 | 12:17 AM
Spids5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Highrevs99 &raquo;</TD></TR><TR><TD CLASS="quote"> I doubt its the shims on a Si trans . You should use a LSD type oil from acura but still that wont make it shutter . The symptom you descirbe is more likely a bad axle , I have had several go bad and do just that vibrate under excelleration . If this unit was used it could be worn out and need of reshimming but I would check my axles first . Oh and I beleive clearance is .1mm on bearings .</TD></TR></TABLE>
I'm still going to check my shims anyways but I'm pretty sure its my axle now. When I turn to the right its really bad and when I turn to the left it doesn't do it. The axle was a rebuilt for a gsr, si and gsr axles have the same part number and they couldn't get si axles so thats why I got the gsr. Do you know if a gsr axle won't work? Is there any axles that you could recommend that can hold more hp than stock?
Old Aug 22, 2003 | 03:07 AM
Highrevs99's Avatar
GSR axles are the same except for the ABS collar . Thats what I have in my hatch .
Old Aug 22, 2003 | 02:40 PM
Spids5's Avatar
What do you think my problem is then? My car vibrates really bad when I'm accelarating in a right turn. It feels like something is lopsided and causes my car to vibrate. My dad seems to think its my lsd, he thinks the gears that control the right side are bad. We are going to pull the tranny out in two weeks but I would rather not if its not the lsd. Someone help me.
Old Aug 22, 2003 | 03:49 PM
drvfast's Avatar
bearings
Old Aug 22, 2003 | 04:23 PM
Audi RS4's Avatar
Lover
i know this might sound stupid, but are your lug nuts torqued down (80-90 ft/lbs)? i've seen some cats forget to tighten those things and the front end feels like it is going to fall off......just a suggestion
Old Aug 22, 2003 | 11:33 PM
Spids5's Avatar
Default Re: Problem with ctr lsd (AK1200)
Yeah I tighten them down, after I put my rims back on I always recheck them after a couple of days of driven. Bearings is the next thing I'm going to check.
Old Aug 23, 2003 | 05:53 AM
DCStreetHtch's Avatar
check for play with the rotor = bad bearing and/or loose axle nut!
-Bryan-
Old Aug 23, 2003 | 06:00 AM
owen_the_soyboy's Avatar
why wouldnt it be the shims?
you guys did NOT check the clearances? why not! argh!
pop an axle out and check!
Old Aug 23, 2003 | 02:57 PM
Spids5's Avatar
Default Re: (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote">why wouldnt it be the shims?
pop an axle out and check!</TD></TR></TABLE>
I know I should of checked them but I did the tranny with my dad who has over 20 years experience as a mechanic and he said they shoud be fine. Tomorrow I'm going to check the axle and the shims, the axle doesn't feel like it has enough freeplay. Everything was torqued down to specs so its nothing like a lose axle nut. I'm still blameing it on the gsr axle or the shims.
00IntegrAllmotoR
Apr 26, 2005 12:13 PM
compwc18
Aug 11, 2004 07:16 PM
blacksheep
Dec 16, 2003 06:44 AM
Spids5
Jul 8, 2003 03:16 PM
Nameless RB26
Dec 9, 2002 01:39 PM
