Precision 95lb/hr injectors in 00 si.....
I have 00 si, aem ems, precision 95lb/hr injectors, a resistor box, obd1 injector clips (didn't know what i was thinking when i bought them) and now 97 dodge neon injector clips with some wiring attatched. The neon clips go right on the injectors, makes sence doesn't it. I need to know how to wire up these clips to the wiring in the 00si. I'm sure i can't plug them on the injector wrong but what wires need to go where? and since i'm wiring right at the injector should i just wire in resistors and forget about the resistor box? Any info would be great.
there is a plug under the intake manifold, that the yel/blk wires from the injectors run into, just pull the plug, pop out the dead end conector,pop out the wires, and check for continuity. put the ones with continutity into the resistor box, and the extra one from the resistor box, into an open spot, where you removed the injector wires, on dead end connector.
What about at the injector itself? I have to somehow hard wire the domestic clips to the 00 si harness. I'll take pics to show what i have and need.....pics are up.
Here are the clips that go onto the injectors, removed from 97 neon...cool now i have the right clips...
I'm guess you are refering to one of these dead plugs....one with yellow and black wires?
the current clips and wiring and resistor box...
What i was thinking...Since i have to wire the clips to the wiring anyway...could i just wire in the resistors needed right into the wiring? Then i could just do everything right there and cover it up with some wire stuff. Would this work? i still have to make sure i put the right wires in the right places. what do you think?
Modified by 80884 at 2:42 PM 9/3/2005
