PR3 A/T ECU Need Chippers Help
Old Feb 22, 2003 | 09:11 AM
zCivic's Avatar
Default PR3 A/T ECU Need Chippers Help
I've been reading up about ecus and hondata says that they convert a A/T ecu to a M/T. Any ideas how this is done. I just got a PR3 A/T ecu with a stock rom and Spoon rom I also noticed that there is a resistor removed. Is that resistor for the A/T lock out switch possably?? So there would be no CEL, right?? Also I've read that the Stock rom suxs for the A/T but would the Spoon rom fix everything so it would run just like the M/T ECU?? This isn't a e-bay rom I got it from a pretty good friend so I trust him on his chips so have no fear about this.
TIA
Old Feb 22, 2003 | 09:56 AM
TimoneX's Avatar
New User
Default Re: PR3 A/T ECU Need Chippers Help (zCivic)
As I recall the A/T ECU has an IC chip that the M/T does not have. I forget which it is, but I do know it's possible to convert between the two.
Old Feb 22, 2003 | 10:47 AM
zCivic's Avatar
Default Re: PR3 A/T ECU Need Chippers Help (TimoneX)
Well if this may jog your memory. It was in socket R68. Next to the Rom chip. Theres 2 lines of resistors a total of 12, 6 in each row. Thats where it is. This pic is kinda fuzzy but may help.
Rom chip is on the right (upside down) and r68 is semi marked. I also semi marked the other resistors around it
Old Feb 22, 2003 | 11:30 AM
TimoneX's Avatar
New User
Ack! That could well be a map to my mother-in-law's house for all I can tell. Surely there are some better photos around. Try Hondata's site, they always have some good info on there.
Old Feb 22, 2003 | 11:42 AM
zCivic's Avatar
I didn't say it was good. It was just a general reference. For some reason my cam will not take clear picture of this, no matter what I do.
Old Feb 22, 2003 | 11:57 AM
zCivic's Avatar
Accually Hondata.com under the downloads has the instructions to convert A/T ECU to M/T. It says move jumper from R68 to R67. Which has been done. Issue solved.
Thanks again
[Modified by zCivic, 4:06 PM 2/22/2003]
Old Feb 22, 2003 | 12:15 PM
eg6ajk's Avatar
here you go one of my how to pics. as far as stock 5spd/auto maps, they are identical. its the rev limit/vtec thats different
Old Feb 22, 2003 | 12:26 PM
TimoneX's Avatar
New User
Default Re: PR3 A/T ECU Need Chippers Help (eg6ajk)
Now there's a pic...go duck dude!
Old Feb 22, 2003 | 12:29 PM
zCivic's Avatar
That is a good pic thanks. that exactly how mine looks now. I also have a Spoon Chip, so that should cure rev limit and v-tec differences. thanks for that. and clearing this issue up for me BTW your from Hyperducktuning.com right or work in conjunction with?? You'll have an order from me in the next few weeks. I'm running a ZIF format so plug and play til I find the one I like the best
[Modified by zCivic, 4:31 PM 2/22/2003]
EFboostedSI
Engine Management and Tuning
May 8, 2009 02:48 PM
KARSON
Mar 4, 2009 04:16 PM
elwood
Sep 11, 2003 11:01 PM
jdmotorsports
Oct 16, 2002 02:50 PM
hondanacura4life
Aug 31, 2002 08:37 AM
