Power windows stop working
Old Aug 31, 2009 | 06:30 AM
95_red_dc's Avatar
Default Power windows stop working
For some reason my power windows stopped working both at the same time. The passenger window is stuck all the way down. How could I jump the window to roll up?
Old Aug 31, 2009 | 08:01 AM
delsolproblems's Avatar
Default Re: Power windows stop working
Check the fuses. If you still need to get em up, you can tap into the wires running from the front of the door (inside jamb) into the car body. Pull the rubber boot out and you'll see the wires. I'm not sure off the top of my head what colors you'll be looking for. GL
Old Aug 31, 2009 | 08:16 AM
phootbag's Avatar
What car? Year? Color? Does it like raisin toast? Need more info...
Old Aug 31, 2009 | 12:52 PM
95_red_dc's Avatar
I checked all the fuses. Its a 95 red integra gsr. I need to find someway to at least get the passenger window up
Old Aug 31, 2009 | 04:26 PM
phootbag's Avatar
Confirm switching voltage at the motor connector. If there isnt any and the motor has continuity you can supply your own voltage to get the window up and diagnose later. If you have switching voltage at the motor connector, the motor is likely bad and you'll have to physically remove it or unbolt the glass and secure the window until you replace the motor.
Old Aug 31, 2009 | 05:40 PM
fcm's Avatar
fcm
Old Fart
Things to check...
Main fuse, fuse 36- 50A, [hot at all times] in engine bay fuse box.
Main window relay fuse, fuse 14 - 20A, [hot in run and start] in under dash fuse box.
Window fuses, fuse 5 -20A (L side) and fuse 8 - 20A, (R side), [hot in run and start] in
Also check the power window relay, also on under dash fuse box.
To get the pass. window up, untill you can fix the problem, you will need to access the plug for the drivers door switchs or the pass. door switch.
If it is the drivers door switch, unplug it and supply power and ground to the blue/green and blue/yellow leads, if it is the pass. switch, unplug it and supply power and ground to the blue/red and blue/white leads.
Because both windows quit working at the same time, and assuming the power windows
are the only things not working, my guess is it will be either the relay or fuse 14.
Before you do anything else make sure the power window main switch, [switch above the the window switches on drivers door] is on, it has no effect on drivers door window, just the pass. window. 94
GsRrrr
Jun 14, 2011 04:02 PM
si_motor_spt
Honda Civic (2001 - 2005)
14
Jul 12, 2010 01:37 PM
4drint3gr4
Mar 16, 2009 02:21 PM
reemer
Nov 29, 2008 08:16 AM
jdm_bones
Jul 19, 2007 12:16 AM
