Power steering removal
Old Dec 26, 2003 | 04:45 PM
SOHC_DK.'s Avatar
Default Power steering removal
Would this be a solution that is accepteble??
OR
would this be the right way to do it??
Wheigt is not a matter here.. ' Only the lasting and how hard it is going to be when you park or drive the car slowly.
M. Nielsen
Modified by SOHC_DK. at 1:29 AM 12/28/2003
Old Dec 26, 2003 | 06:34 PM
99blackcivicSi's Avatar
Default Re: Power steering removal (SOHC_DK.)
#2 is the best way to do it if you keep the power rack, someone on this board sells the kit i forget who though. I just have mine looped without a breather but i am getting a manual rack.
Old Dec 26, 2003 | 08:33 PM
StyleTEG's Avatar
Default Re: Power steering removal (99blackcivicSi)
The first way works, I ran my car like that for awhile.
Eventually switched it for a loop system, which I bought through padawan on this site. Looped is much MUCH better.
Old Dec 27, 2003 | 03:32 AM
SOHC_DK.'s Avatar
Default Re: Power steering removal (StyleTEG)
Whats the difference between the first option and the 2nd.?? both are looped with a reservoir.. only difference I see is that the number 1 has got longer hoses.. and it could therefor be harder to force the fluid around...... Or am I wrong??
M. Nielsen
Old Dec 27, 2003 | 03:59 AM
Zeus Zore's Avatar
just following.....
Old Dec 27, 2003 | 05:23 AM
K20EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">#2 is the best way to do it if you keep the power rack, someone on this board sells the kit i forget who though. I just have mine looped without a breather but i am getting a manual rack. </TD></TR></TABLE>
Old Dec 27, 2003 | 09:18 AM
fkncivic's Avatar
Default Re: Power steering removal (K20EG)
i just removed all the lines and capped off all the holes lol i tried a manual rach but honda kept ordering me the wrong uv joint so i just put my old one back in...
Old Dec 27, 2003 | 01:08 PM
SOHC_DK.'s Avatar
Default Re: Power steering removal (fkncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkncivic &raquo;</TD></TR><TR><TD CLASS="quote">i just removed all the lines and capped off all the holes lol i tried a manual rach but honda kept ordering me the wrong uv joint so i just put my old one back in...</TD></TR></TABLE>
Does anybody know where I can buy the "kit" to remove powersteering.. I assume it includes hoses, fittings, the "T" and the exstra reservoir..??
I have serched, but cant find a decent "How TO" (only one without pics')
M. Nielsen
Old Dec 27, 2003 | 03:39 PM
StyleTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_DK. &raquo;</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jan 1, 2004 | 02:35 PM
SOHC_DK.'s Avatar
ok.. thanks.. But how much difference is there when turning the wheels?? Is it the same, or would it be easier with the No, 2 solution???
M. Nielsen
Old Jan 1, 2004 | 04:53 PM
Zeus Zore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_DK. &raquo;</TD></TR><TR><TD CLASS="quote">ok.. thanks.. But how much difference is there when turning the wheels?? Is it the same, or would it be easier with the No, 2 solution???
M. Nielsen</TD></TR></TABLE>
i would like 2 know that 2 !!
Old Jan 1, 2004 | 06:08 PM
StyleTEG's Avatar
Default Re: Power steering removal (Zeus Zore)
It is easier with the second sollution, ie done properly.
Old Jan 1, 2004 | 09:59 PM
allmotorsi04's Avatar
my fried just put one on his type-r last night, let me find out what the name of the company was and i will let you know....been thinking about putting one on my coupe....
Old Jan 1, 2004 | 10:12 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Power steering removal (allmotorsi04)
looks like you are making more work of it then it's worth. just remove all the lines and make a loop @ the rack after you empty all the fluid.... you don't need a resevoir. you could probably just cap those two holes but i'd be interested to know if it was much harder to stear since it couldn't move any air when you cut the wheel.
-Erik &lt;---- looped it with 6" of hose, no fluid, no resevoir, no problems...1
Old Jan 2, 2004 | 12:42 AM
SOHC_DK.'s Avatar
Default Re: Power steering removal (Erik_Pb_Foot)
sounds interesting.. could you post some pics, or send them : vtec@stribnet.dk
I think I will try the easy way first just to see what the difference is.
M. Nielsen
Old Jan 2, 2004 | 07:34 AM
New User
the difference would be the same as just removing the belt from the ps pump.....
Old Jan 2, 2004 | 07:48 AM
SOHC_DK.'s Avatar
Default Re: (Erik_Pb_Foot)
would that be much harder or almost the same..??
On a scale from 1-10 where 10 is the easy way done, where would the loop/reservoir solution be???
Old Jan 2, 2004 | 04:39 PM
New User
Default Re: (SOHC_DK.)
i don't understand your question. if you are just wanting an easy way to "disable" your ps then take the belt off. if you want to remove it the correct way, get a manual rack. if you wanna remove all the stuff but are poor like me then just remove everything and loop the two spots on your rack that fluid enters/exits.....
Old Jan 2, 2004 | 11:25 PM
SOHC_DK.'s Avatar
Here's the problem..
I am going to a garage today to make it, just wanna make sure that I dont mess things up.
M. Nielsen
Old Jan 3, 2004 | 12:14 AM
EKFerioHawaii's Avatar
I vote for the second option.
Heres a link to help you out. https://honda-tech.com/zerothread?id=184202
If its good for realtime racing, then its good for me.
Good Luck.
Old Jan 3, 2004 | 05:06 AM
New User
Default Re: (EKFerioHawaii)
you guys quit whining and just do this. it makes no sense to go through all the trouble of splicing this, zip tieing this, duck taping this, removing this, yada yada yada. just do like that picture from the link and drive it. that's how mine is done, that's how everyone else i know has done theirs... and nobody has any problems... period
-Erik
DAcraze
Jan 11, 2020 04:06 PM
Dragginglass
Mar 27, 2008 02:36 PM
spintboy
Feb 23, 2008 10:30 AM
sohc_freak
18
May 24, 2006 07:56 PM
jdmwannabe3
12
Apr 26, 2006 12:02 PM
