Power steering pump access
Old Aug 30, 2010 | 07:44 PM
Atomic1's Avatar
Default Power steering pump access
Basic question, how do you guys move the power steering pump to the side when accessing things below? (like a/c belt) Unbolting it is easy, but there's not much slack in the hoses to really move it anywhere. Just wondering if there's a trick of some sort. Do you have to unclip the resevoir? Use wire to hold it aside?
Old Aug 30, 2010 | 07:59 PM
mouab18c1's Avatar
Default Re: Power steering pump access
Make sure you unbolted the 10mm that holds onto the hose bolted onto the valve cover. I usually unbolt the power steering remove the resevoir off the clip and just push it to the side. Its annoying but it wont hurt to tie it down
rolledthatho
13
Feb 12, 2011 06:13 AM
EM2_touge
Honda Civic (2001 - 2005)
20
Jun 20, 2009 02:49 PM
thebleek
Sep 28, 2008 11:14 AM
deacs
Oct 15, 2002 11:56 AM
