b16a crx problem
Old Aug 24, 2010 | 02:20 PM
d16z6EG's Avatar
Icon2 b16a crx problem
ok i have a b16a crx and every morning or when it sits for a while it will crank over for a bit and on occasion sound like the starter just locks up for a second then starts up or it will crank over for a bit then start but idle really low then pick up untill normal idle. If its been warmed up it starts up no problem. sometimes it sounds like fuel pump doesnt come on at first could this be fuel relay maybe? its throwing no codes and runs great just worried its going to get worst to the point it just wont start.
Old Aug 25, 2010 | 07:06 PM
Canuck99's Avatar
Default Re: b16a crx problem
To far advance on the base ignition timing will give you a hard start cold and a locking up as well juring cranking, maybe check the valve timing as well?
Old Aug 26, 2010 | 04:41 PM
d16z6EG's Avatar
will do asap thanks
Old Aug 30, 2010 | 01:22 PM
d16z6EG's Avatar
is the base timing 16 degrees btdc? jdm and usdm the same?
Old Aug 31, 2010 | 04:52 AM
Canuck99's Avatar
12 +/-2 Not sure about the diffrence but all I have is Can/UA specs
Jdm256
Aug 16, 2015 12:03 PM
Dangousity
Feb 10, 2010 03:58 AM
XspeedSi02
Mar 3, 2008 09:51 PM
EF8_SiR
Aug 29, 2002 01:22 PM
