power mirror/window conversion
i was jus wonderin wat all i need to do the power mirror conversion. i've been thinking about doin this, and also, but not of much importance, the power windows. reason being, i found some cheap coupe door panels, an if it's not gonna kick my ***, i was thinkin about purchasing them for now, and later do the conversion???
This has been covered many many times. It is very easy. search for jacksrepo thread or something like that. It is a nice write up. Basically get the power stuff bolt it in place of non power stuff. For the wires you can take the floor harness and door harnesses off a the ex model of your year. It's basically plug and play. Or if you are good with soldering you can make your own wire connections. You will also need the switches and relays/fuses. Power locks is what made me do it, keyless entry!!
quik ???. i was reading the thread on how to install the power windows, great info, but wat if my model never came with power mirrors. do all civics come with standard wiring for this option like they do for the clock???or do i have to start from nothing and run the complete wiring????
jumai182
Jan 2, 2024 09:10 AM
jdmwidebody094
Sep 10, 2005 06:58 PM
00_whytehatch
Jun 1, 2005 10:06 PM
