Is it possible to remove rocker shafts with the head installed in the car?
Old Feb 16, 2007 | 10:33 PM
DaiJekBok's Avatar
Default Is it possible to remove rocker shafts with the head installed in the car?
EDIT: Looks like they can exit the head on the passenger side as well. That's what you get for starting projects at midnight.
Old Feb 18, 2007 | 12:39 AM
EnjoyTheRideDC2's Avatar
Default Re: Is it possible to remove rocker shafts with the head installed in the car? (DaiJekBok)
remove the gold 10mm allen head screws from the drivers side of the head, the one from the passenger side, and the vtec solenoid assembly. Then get a 12mm bolt, thread it into the rocker shaft on the passenger side until the thread stops, and slowly pull the shaft out towards you, while removing the rocker assembly section by section.
Old Feb 19, 2007 | 04:30 PM
PHDZINE's Avatar
Default Re: Is it possible to remove rocker shafts with the head installed in the car? (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">remove the gold 10mm allen head screws from the drivers side of the head, the one from the passenger side, and the vtec solenoid assembly. Then get a 12mm bolt, thread it into the rocker shaft on the passenger side until the thread stops, and slowly pull the shaft out towards you, while removing the rocker assembly section by section.</TD></TR></TABLE>
X2
Old Feb 20, 2007 | 07:46 AM
RACEPAK's Avatar
Default Re: Is it possible to remove rocker shafts with the head installed in the car? (PHDZINE)
strap each set with a rubber band before you pull the shaft.....
Old Feb 20, 2007 | 10:30 AM
DaiJekBok's Avatar
Default Re: Is it possible to remove rocker shafts with the head installed in the car? (RACEPAK)
Thanks for the replies. I was looking at a diagram that showed the shafts to the right of the head and did not realize that you can also pull them from the passenger side as well.
Got it all taken care of and she runs like a champ!
Old Feb 20, 2007 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies. I was looking at a diagram that showed the shafts to the right of the head and did not realize that you can also pull them from the passenger side as well.
Got it all taken care of and she runs like a champ!</TD></TR></TABLE>
Yup, they can be removed from either side, but the helms manual instructs to remove from the passenger side using a bolt. But there are other ways of doing a lot of things..
oldskoolaccord
Feb 18, 2009 06:11 PM
Firestarter
Nov 5, 2005 01:30 PM
Short Round
Jul 17, 2003 12:09 PM
B_CRUZ!
Jan 10, 2002 10:49 PM
