possible reasons for not having spark
Old Sep 13, 2003 | 07:36 AM
crxY-49's Avatar
Default possible reasons for not having spark
i just installed a turbo kit on my my and now i can't get it started and now I have no spark. i've installed a new cap, rotor, and got my ignition coil tested. The only other thing i could think could cause this would be my ignitor. Could a my main relay cause this? I can still hear the fuel pump kick on though. thanks
Old Sep 13, 2003 | 09:43 AM
TeStUdO's Avatar
Im thinkin either the dizzy or ignitor. Was your car running fine before the install of the turbo??
Old Sep 13, 2003 | 10:34 AM
mmuller's Avatar
Mad Scientist
Default Re: (TeStUdO)
[QUOTE=TeStUdO]Im thinkin either the dizzy or ignitor.[QUOTE]
Old Sep 13, 2003 | 12:16 PM
KayOs's Avatar
sounds like an igniter problem.
Old Sep 13, 2003 | 01:43 PM
Turbo12acer's Avatar
ignition module?
Old Sep 13, 2003 | 03:48 PM
B18C1-ED8's Avatar
Default Re: (Turbo12acer)
it has to be the ignitor...i had the same problem a couple of months ago, replaced it, now it runs like a champ.
Old Sep 13, 2003 | 07:56 PM
crxY-49's Avatar
Default Re: (97CivicTypeRCoupe)
yeah, the car was running fine before i installed the turbo kit. can i take my ignitor to autozone to get it tested? i hope thats the problem. thanks
Old Sep 13, 2003 | 08:32 PM
ion_four's Avatar
Default Re: (crxY-49)
I had the same prob, thought it was the ignitor, since the coil tested fine, but when I replaced it there was still no spark! So, I replaced the coil and it fired right up! Moral being that the coil resistance tests are crap. Utter crap. You have to get it tested on a special machine that puts a load on it, or some-such. After I brought it to a honda master tech, he informed me of this.
Old Sep 13, 2003 | 09:08 PM
Stripped Honda's Avatar
99-0104
Default Re: (ion_four)
sence you just installed a turbo ... maybe you didnt hook up a ground wire ??? that seems like the most common thing to happen on a install when your having problems
platinum00
Jul 26, 2009 06:31 PM
Lokisdope
Dec 25, 2007 05:49 PM
JTCdudeman
Nov 22, 2003 10:37 PM
